What is normal oil pressure at idle?
Discussion in 'SRT Hellcat Performance' started by WNY Cat, Jan 11, 2015.
  1. WNY Cat
    Nov 16, 2014
    566
    358
    513
    I'm just curious. I only have 300 miles on my Hellcat and it's currently stored for the winter. I pulled it out of the garage today and started it up. After it got warmed up, I went into the performance pages to check the gauges and the oil pressure was 37psi at idle. What's normal?
  2. Jim Hetrick
    Jim Hetrick Silver Member
    Dec 5, 2014
    1,338
    263
    108
    Orange County Cal
    Sounds about right, what was the temp at ??
  3. WNY Cat
    Nov 16, 2014
    566
    358
    513
    I think the engine temp was 201. Outside temp was 28. It's back in the garage covered up now. :(
  4. HellcatKid
    HellcatKid Silver Member
    Dec 21, 2014
    451
    106
    CANADA
    FYI Generally as a mechanics rule of thumb the minimum required is 10 psi per 1000 rpm so assuming idle is somewhere around 750 rpm them 7 and a half pounds will protect your bearings. I would be more concerned what it is at around 6000rpm.
  5. B5 Blue
    1,743
    Amen to that!
  6. fnkychkn
    Jan 24, 2015
    1,451
    558
    423
    plastic take-out container
    oil pressure specification:
    minimum 13 psi (90 kpa) @ curb idle.
    25-110 psi (170-758 kpa) @ 3000 rpm.
    • Useful Useful x 2
  7. SUPERCOOLSRT
    SUPERCOOLSRT VIP Hellcat Member
    Nov 18, 2015
    128
    62
    98
    Huntington Beach, ca
    Where are these numbers from
    Mine is at 35% @85% oil life left
    1000 miles on cat
    Does this look normal
    Thoughts
  8. terryturner
    terryturner Gold Member
    Apr 1, 2015
    1,024
    252
    Newport, MI
    Mine is also at 35 psi at idle
  9. SUPERCOOLSRT
    Nov 18, 2015
    128
    62
    98
    What was the solution to this issue did you have new parts ordered did they come in from the dealer or do you have it unfixed at this moment.
    Tell us a little bit about it
    how many miles was on it when this happened was it higher oil pressure and then as it was less oil the pressure as the oil level went down as well thanks for the info kind of a geek when I comes to the stuff I love info
    Thanks
    Rob
  10. terryturner
    Apr 1, 2015
    1,024
    252
    Newport, MI
    It's still at 35. Haven't drove it for about 2 months. Currently at 720 miles. I didn't realize it was an issue
  11. TallCool1
    2,401
    798
    Pacific NW
    That's normal no issue.
  12. BULL
    BULL ________173.7mph_______ ___2016 Colorado Mile___ Gold Supporting Member
    Nov 20, 2014
    2,312
    704
    Colorado
    At low engine speeds (idle), my pressure is very sensitive to what the actual rpm is, so there is proportionally large psi deltas with small rpm differences. If your car is "idling" even slightly low, you'll see what might seem like a "low" oil pressure, but it's directly proportional to engine rpm, unlike at higher rpm where you're getting into the filter bypass and other things.
    Mine drops (momentarily) to 35-40 with the engine at low-idle... and fluctuates around 48-55
    As long as it comes up to ~50psi or more at 1000rpm, I think you're inline with everybody else.
    And then 55psi (or more) at "normal" driving rpm*.
    Mine runs 55-62 at normal rpm and spikes even higher with higher rpm
    *I haven't had mine super hot on a hot day to know what pressures would be under those circumstances.
  13. SUPERCOOLSRT
    Nov 18, 2015
    128
    62
    98
    Bull
    Awesome and thanks
    Big help
    Cheers
  14. gilgamesh
    gilgamesh Silver Member
    Sep 20, 2014
    350
    118
    Mine chills around 60-65 PSI at interstate cruising and jumps around 70 at WOT.
  15. BULL
    Nov 20, 2014
    2,312
    704
    Colorado
    SUPERCOOLSRT
    So with this question in mind, I took some pictures of my pressure and temps when I went out today...
    Cold, engine, oil temp 60F...
    ~60min later, trip to the bank and the post office
    Difference is car is fully warm...
    Idle...
    Parked, holding rpm with peddle..
    If you're getting something significantly different (lower) than this, the very first, low-dollar, low-risk, nothing lost thing you could do is change your oil-filer (and oil).
    You might have a defective by-pass in your filter... (you could have a 100 other things as well)
23 psi oil pressure charger
dodge challenger oil pressure at idle
dodge durango normal oil pressure 2015
hellcat oil pressure
normal coolant pressure dodge charger
normal oil pressure dodge durango
oil pressure dodge charger
what is the normal oil pressure for a chrysler 300 2014
