What is your normal operating Coolant temp?
Discussion in 'Dodge Challenger SRT Hellcat' started by cjohn7, Jul 15, 2015.
  1. cjohn7
    cjohn7 VIP Hellcat Member
    Apr 13, 2015
    129
    61
    98
    While driving my temp stays around 206.
    however in traffic it stays around 217-222. once hitting 223 the fan comes on high and cools it down. but it mostly stays in that 217-222 range.
    Just wondering if that 217-222 range is normal or am I running a little hot and should have it checked out?
  2. Hellcharger
    Hellcharger Senior Hellcat Member
    Apr 25, 2015
    86
    75
    My charger runs about the same temps but averages a little lower like 210-215
  3. tsubahog
    tsubahog Gold Member
    Mar 30, 2015
    370
    172
    NJ
    Exactly the same ^^^^^
  4. B5 Blue
    1,747
    Temp is okay
  5. One Ton Racer
    One Ton Racer Silver Member
    Feb 18, 2015
    174
    56
    178
    New Brunswick, Canada
    203 if fan not needed. That is where thermostat opens.
    216 at idle or in traffic.
    Yours is fine.
  6. Lee
    Lee Rookie
    Aug 9, 2015
    21
    Mine is the same too I was wondering that too but dealer said normal
  7. Jungle Cat
    Jungle Cat Gold Member
    Feb 24, 2016
    1,330
    320
    258
    My Challenger runs on the highway at 206 as well. Strange thing is with AC on and hitting some stop and go traffic the fan came on and temp went below 200 and stayed there while in stop and go situation. Pretty good cooling feature I thought.
  8. Racist Cat
    Racist Cat Gold Member
    Jan 28, 2016
    1,620
    673
    This is because the fan is needed to cool the condenser.
    Running with the a/c off will produce high water temps, although it may lower under hood temps and reduce heat soak.
    Running with the a/c in traffic, the fan has to run to keep the condenser cool regardless of water temp.
  9. Jungle Cat
    Feb 24, 2016
    1,330
    320
    258
    Good info. Whenever I get stuck in traffic for any extended time for maybe over 15 minutes the AC always goes off on any car I own. Would rather roast myself than my engines.
  10. Racist Cat
    Jan 28, 2016
    1,620
    673
    The fan would run more often, keeping water temps cooler....
  11. Racist Cat
    Jan 28, 2016
    1,620
    673
    When the a/c is on, the fan is slave to it, regardless of water temps.
    If the a/c is off, the fan runs according to water temps. Usually only engaging just before overheat.
  12. Tammie
    Sep 11, 2014
    13,564
    4,650
    1,223
    Washington
    Yep, all normal. If you are worried, get on the freeway and hit it. Cools right down.;) Of course explaining that to the police is a whole other thread.:p
average running temp for 2016 dodge dart
challenger coolant temp
charger srt8 normal coolant temp
dodge dart average coolant temperature
dodge dart running tempersture
normal coolant temp 2013 srt8 jeep
what is the coolant temperature supposed to be srt
what should the temperature be on 2015 dodge dart
