wheel offset
Discussion in 'SRT Hellcat Wheels and Tires' started by Fastlane_wood, Mar 2, 2016.
  1. Fastlane_wood
    Fastlane_wood Hellcat Member
    Aug 13, 2015
    36
    21
    would a +38 offset clear our brakes i found a nice set of wheels out of state but was sure if they would clear and if not between what and what number should clear our brakes far as offset
  2. Driver72
    Driver72 Gold Member
    Mar 10, 2015
    1,216
    281
    You need to post the width of the rim you are looking at too and if you are talking front or rear wheels.
    But I don't think any rim of 9.5-11 inches wide would fit with a 38 offset.
    Not only would it probably hit the brakes, but it would definitely hit on the inside, i.e.: a suspension, steering part, or wheel well).
    You want to be in the 15 (will stick out further) to 26 (will tuck under wheel well more) range for most 9.5 to 11 inch wide wheels. There is little room in the front too, so you'd probably need more like 15 to 20 offset for most front wheels.
    Just for reference the stock 9.5 inch wide wheels have an offset of roughly 18.5
  3. Radride
    Radride Silver Member
    Jan 15, 2016
    976
    186
    Up Here!!!
    Offset doesn't determine caliper clearance. The face design of the wheel does.
    R.K.
  4. Driver72
    Mar 10, 2015
    1,216
    281
    This is true too, but make no mistake, offset has an effect on caliper clearance. There is only so much wheel design they can do and keep the integrity of the wheel, so you can't have an offset of 38 but then have spokes that stick way out to clear the brake calipers, without seriously compromising the strength of the wheel.
hellcat factory wheel offset
hellcat offset wheel
what is the wheel offset on a hellcat
wheel offset hellcat
