Wheel rubbing with 305's
Discussion in 'SRT Hellcat Wheels and Tires' started by Biscuit60140, Jun 20, 2015.
  1. Biscuit60140
    Biscuit60140 Hellcat Member
    Apr 6, 2015
    37
    16
    Hello...
    At 1200 miles I swapped out my stock summer tires for 305/35 Nitto 555R's. I am at 3300 miles now and never noticed a problem with rubbing noise when going through turns. I went to the drag strip for the first time Thursday and ran it hard but not abusive. Now I have noticed I get what I can only describe as a rubbing from the drivers rear when making right hand turns at about 10mph up through 25mph. If I go slower I don't hear anything. I think... maybe it's all in my head... I have heard it on left turns but no where near as often. I tried to inspect what I could see without the car being on a lift and I can't see anything that looks like rub marks.
    Has anyone else experienced this? Any thoughts on what I should look for/at??
    Craig
  2. B5 Blue
    1,745
    Flashlight and a mirror for wheel well, mirror for 1/4 panel I would do.
  3. Biscuit60140
    Apr 6, 2015
    37
    16
    I looked over things last night and don't seem to be able to find any proof of rubbing. I also did some driving, only seems to make the sound during right turns, not on lefts. Ugh, thinking this means a trip to the dealer....
  4. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,030
    Probably the plastic inner wheel well,, they have been known to rub on turns,,,,,
  5. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,122
    739
    take the 305's off the fronts...i kept the stock tires on the fronts....dont see a reason for drag radials on the fronts? what is the reason? to me it just gives you worse/sloppier turns.....
  6. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    805
    563
    Put a screw in both wheel wells plastic cover all the way left corner bottom both sides you see is the wheel wells looses point
    Driver side is left
    Passenger is right of corner wheel well
    Or use heat and mold it back a few
  7. Biscuit60140
    Apr 6, 2015
    37
    16
    Did I miss something? Who said anything about DR's up front?? Are you assuming because I said I swapped out my stock summer tires I did all 4? I am talking about the rear tires, the rubbing is from the drivers side rear.
    Anyway, I agree with those who are suggesting I look at the plastic cover, that is all I can think. My guess is maybe something came loose at the track since that is when it started.
  8. DGatzby
    Jan 16, 2015
    3,270
    1,669
    598
    Twin Cities, MN
    ^ I have had my hands in the drivers rear with those tires. So it should not be rubbing. Look first at the rib inside front. It would be strange if it was rubbing there. If it is, then unfortunately you have an orphan because I have not seen anybody say that rubs with the 305's and the OEM wheels (18.5mm backset). Then the rear liner. That is easy to move out, my guess is that maybe it is easy for yours to be in just a bit? If so that is easy to fix.
  9. seandtc
    seandtc Rookie
    Mar 26, 2015
    28
    10
    Dealer for sure. Done four hellcats 3 with 305s one with 315 with no rub. 305s don't fit the front anyway
  10. huggytree
    Nov 22, 2014
    3,122
    739
    i figured you put 305's on the fronts since you said it was rubbing when you turn....why would it rub when turning on the back? unless you have 4 wheel steering?/??
    my 305's have no rub issues
    take it to the dealer...something is wrong.....
  11. B5 Blue
    1,745
    Sidewalls give on slicks so you can get rub turning on to the return road at track if they are close but OP says no rub.
  12. Biscuit60140
    Apr 6, 2015
    37
    16
    Decided I'm going to have to take it in since I can't seem to see anything. Worst part is I will be on vacation starting later this week so I'll have to wait until I get back, no way I'd leave it with them for a week....
  13. Paladin06
    Sep 3, 2014
    4,701
    1,853
    San Tan Valley, AZ
    I noted when I put the same tires on the rear that the drivers side rear outer area of the fender wheel well plastic panel was about 1/8 inch from the tire. I cut a small area from the plastic and now have about 1/2 clearance. I shaped it nicely and it looks factory.
    Good luck
  14. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    805
    563
    Oem is 275 how dealer gonna help you wit 305 tire
    • Agree Agree x 4
  15. Slowhand
    Slowhand Gold Member
    Jan 26, 2015
    605
    263
    Maryland by the bay
    GoPro camera mounted with a suction cup should show you what is happening.
305 wheel on hellcat
hellcat scraping noise
why does it sound like rubbing when i turn left in my 2016 hellcat
