Wheel Widening
Discussion in 'SRT Hellcat Wheels and Tires' started by Suprcat, Jan 30, 2016.
  1. Suprcat
    Suprcat Senior Hellcat Member
    Jan 23, 2016
    73
    28
    Prior Lake, Minnesota
    Has anyone had their factory rear wheels widened to 11 inches? I am looking at purchasing 2 new Brass Monkey wheels and having this done to keep the factory look and still run 315/35r20 tires. I have found 2 places that may be able to do this - weldcraftwheels.com and ericvaughnmachine.com - any thoughts?
  2. terryturner
    terryturner Gold Member
    Apr 1, 2015
    1,014
    250
    Newport, MI
    I personally would just buy 2 forged rims that are already 11" This amount of torque on a widened wheel is sketchy to me especially when u start adding power
  3. Suprcat
    Jan 23, 2016
    73
    28
    They claim when professionally welded they will hold up as well as the original, if not stronger at the weld.
  4. Darin Gosoir
    Darin Gosoir Hellcat Member
    Oct 30, 2014
    93
    36
    18
    Minnesota
    Just sent my rear wheels ( billet spec.) to Eric Vaughn last week to get widened to 11", he is a little more $ but way better job, all computer cut& welded, he adds a new hoop to the back side, where weldcraft adds in a 1" piece so you have 2 weld joints
    • Useful Useful x 2
  5. gavm360
    gavm360 Senior Hellcat Member
    Mar 30, 2015
    81
    30
    Interested. Been watching to see someone do this.
  6. rags
    rags Hellcat Member
    Dec 27, 2015
    77
    16
    Westwood, NJ
    Search. It has been done. There are issues with clearance even behind the plastic liner. One member had a triangle section cut out of the frame to gain some room. Let me search for the thread I'm thinking of.
  7. rags
    rags Hellcat Member
    Dec 27, 2015
    77
    16
    Westwood, NJ
  8. gavm360
    Mar 30, 2015
    81
    30
    Has anyone done 1" widening to 10.5 and used 305s?
  9. rags
    rags Hellcat Member
    Dec 27, 2015
    77
    16
    Westwood, NJ
  10. DGatzby
    Jan 16, 2015
    3,097
    1,558
    598
    Twin Cities, MN
    You should be able to widen the wheels and use 305/35's no problem. They fit stock. Tire controls hitting the inner liner.
    Besides we are using a 10.5" wheel with a 27 mm backset and Nitto 315/35's and clearing!
  11. BATTLECAT
    BATTLECAT Hellcat Member
    Aug 10, 2015
    30
    12
    Morton Grove, IL
    Is it possible to find a company that can make the exact factory wheel with the exact specs we need to fit a 315 DR tire? Also with out costing a fortune lol
  12. El-Gato
    El-Gato Senior Hellcat Member
    Dec 16, 2015
    70
    54
    Why cut and widen a forged wheel just order a 11" forged wheel ??
  13. rags
    rags Hellcat Member
    Dec 27, 2015
    77
    16
    Westwood, NJ
    So you are increasing the backspacing by about 4/5" and having the rim stick out 1/5" closer to the fender lip with 315's and don't have an issue at all with rubbing anywhere? This is good info! I'm no machinist but a call to Eric Vaughn to see if his 1" widing of our wheels with a .2" thick spacer welded to the inside of the rim contact patch would give the same config.
  14. Bandit
    Bandit Gold Member
    Jun 20, 2015
    974
    304
    For those that want to use this on the street daily, and don't want mismatched wheels.
  15. Billet Hellcat
    Billet Hellcat Gold Member
    Dec 2, 2014
    1,064
    645
    413
    So Cal
    You can ad 1" to the stock wheel and it will clear the inside making the wheel a 20x10.5 with 30mm offset but if you go 1.5" you would need to run a 1/2" wheel spacer and it would push your wheel out 1/2". If you are going to have a stock rear set widened I would only go 1" wider.
