When are your fans kicking on?
Discussion in 'SRT Hellcat General Discussions' started by usmc341, Apr 17, 2016.
  1. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,714
    497
    368
    Henderson, NV
    Sitting in traffic today noticed the temp gauge creeping up past the half way point. Never noticed it before so I scrolled to coolant temp and it seems like 219 is the magic number where the PCM turns the fans on. Seems a bit high but as soon as she hit that mark coolant temps plummeted. Sound about right?
  2. TallCool1
    2,439
    829
    Pacific NW
    Sounds about right amigo.
  3. bigsursteelhead
    bigsursteelhead SRT Hellcat Supporter Gold Supporting Member
    Sep 21, 2015
    108
    56
    168
    NorCal
    Noticed mine doing the same thing but funny thing is the temp gage seems twitchy when that happens - then fan comes on - and shortly temp drops. Had my attention first time it did that
  4. tsubahog
    tsubahog Gold Member
    Mar 30, 2015
    361
    172
    NJ
    224 then drops quickly
  5. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,714
    497
    368
    Henderson, NV
    If it's anything like the Shelby it has a low speed/high speed loop. Tough to tell these fans are pretty quiet on the Hellcat
  6. TallCool1
    2,439
    829
    Pacific NW
    2 stage. Was posted long ago but yup.
  7. RammJaeger
    RammJaeger Silver Member
    Oct 11, 2014
    326
    135
    I had never heard mine kick on high speed before a couple of days ago. I got up to 222 degrees. The last couple of days I've been watching it, and even when I stop at a stoplight it gets up to 220 or so. Is this normal? I'm thinking about taking it in to get looked at, as I never saw it over halfway before.
  8. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,714
    497
    368
    Henderson, NV
    From what I'm hearing from other members it's normal. I just never noticed it before. PCM has set parameters and it appears we are all in the same ballpark
  9. Racist Cat
    Racist Cat Gold Member
    Jan 28, 2016
    1,598
    655
    222-224 is what I see daily.
    My house is in a subdivision, and has a fairly long uphill run to the driveway, and I always back in. Usually right about the time I'm slowing down from backing in, the temp is in the 220 range and climbing. Hits about 223 and the fans kick in and pull it down in just a few seconds. I usually open the door and listen to the exhaust rumble and the fans to kick off before shutting down.
    If you drive with the a/c off, you will see higher temps more often since the fans don't have to kick on to cool the condenser.
    However, you will probably have less heat soak. So even though you have higher water temps, you might make more power. I drive with my a/c off whenever possible.
  10. Mopar Magic
    Mopar Magic Hellcat Member
    Aug 13, 2015
    93
    25
    18
    Wichita, KS
    This is what I see as well. It also worried me. 224 seems pretty hot...
