Which hi temp brake fluid?
Discussion in 'SRT Hellcat Performance' started by Hb hellcat, Oct 3, 2015.
  1. Hb hellcat
    Hb hellcat Black Betty...BamAlam!!!
    Feb 14, 2015
    594
    Sunny Southern California
    ran the "roval" at Fontana today and started getting some brake fade by end of 2nd session. Let everything cool and by last third of third session was really having an issue with slowing!
    By smells and visual inspection, it's apparent I boiled the brake fluid.
    What dot grade and brand do you guys think should be run?
    I've always used Motul in the past, is there some new tech wonder fluid out there?
    Inquiring minds want to know and Thank You for any feedback
    Btw, top speed 150 entering the high banks and weighed 4890 pounds with 1/4 tank of gas and me in it. Them brakes got a LOT of work to do!
  2. NorCaletch19He77Kat
    Aug 30, 2015
    941
    284
    173
    how do you know it was the fluid and not the rotors??
  3. Hb hellcat
    Feb 14, 2015
    594
    While the rotors and pads were smoking when I came off the track, that was a different smell. Smelled like burnt brakes, I can do that to most cars, mostly rentals, and I'm very familiar with it. This also wasn't like usual when I've over cooked the pads, again, been there, done that with almost everything I drive.
    I do enjoy driving.
    This was a new smell, kinda sweet.
    Easily replicated by removing the brake fluid reservoir cap and smelling.
    There was also quite a bit of oil residue on the driver side valve cover and firewall plastic trim. Determined to be power steering fluid! Guess will need to be looking at that as well. Very hot cap, too hot to touch bare handed. (Billet tech beauty caps). Saw similar issues with other srt cars not just hellcats, so will look further into those solutions.
    Mainly looking for input on brake fluid knowledge and recommendations for fluids that meet Chrysler warranty specs with a much higher boiling point than currently used by the factory.
    Thank you for your input!
  4. TallCool1
    2,438
    829
    Pacific NW
    Look here. You don't need to spend an arm and leg on RT700. In the thread below you'll see links to specs and comparisons. I punished the stuff heat wise 0 issue.
    683F boiling point.
    Brake fluid change or flush prior to a track day | SRT Hellcat Forum
    http://www.amazon.com/Torque-RT700-Performance-Racing-Single/dp/B00IITUPCS
  5. NorCaletch19He77Kat
    Aug 30, 2015
    941
    284
    173
    careful what you do--can get worse..
    how many miles on the brakes now?
  6. Meat
    Meat Hellcat Member
    Sep 12, 2015
    46
    12
    Huntsville, AL
    When I roadraced motorcycles I used Castrol SRF brake fluid. It has the highest wet boiling point that I know of. Wet boiling point is what I would be concerned with not the dry boiling point.
  7. Hb hellcat
    Feb 14, 2015
    594
    Thanks for the links and input.
    Just over 3000 miles, one auto cross, the big track day, and lots of drag races. So not what you would call easy miles.
  8. TallCool1
    2,438
    829
    Pacific NW
    RT700 specs right up there with SRF, at about half the cost. Less hygroscopic too. Slight nod for compression. I like the Castrol but they can pack sand at its price point and I'd rather use usa made. I saw nothing gained or lost in cars or bikes between SRF and RT700. (I raced the multistrada using RT700, and the SRF, horrible on brake fluid rear master / pump inches away from the cat.) SRF and RT700 are the 2 to use though, imho.
  9. TallCool1
    2,438
    829
    Pacific NW
    Welcome if you switch change annually minimum to deal with water absorbtion (if you choose SRF or RT700.)
  10. redhemi
    redhemi Gold Member
    Dec 9, 2014
    473
    222
    southeast Pa.
    In the 5th edition OM pg 275 it describes how too seat your brake pads for track use,sounds like you over heated the pads and now there glazed!!
  11. Meat
    Meat Hellcat Member
    Sep 12, 2015
    46
    12
    Huntsville, AL
    On Amazon it lists the wet boiling point of the RT700 as 439 degrees F @ $34 for 16.9 oz ($2.01/oz). The wet boiling point of the SRF is 518 degrees F @ $63/qt ($1.97/oz).
  12. TallCool1
    2,438
    829
    Pacific NW
    My bad you're right. That was less significant to me I changed fluids often racing. What I focused on was compression and air absorbtion mostly. Both fluids are hygroscopic I never saw a performance bene that justified the srf price. They're both really good.
  13. Hb hellcat
    Feb 14, 2015
    594
    Thanks again for all the input!
    Down to castrol or torque!
  14. BULL
    Nov 20, 2014
    3,432
    1,137
    628
hellcat brake specs
best high temp brake fluid for dodge challenger rt
hellcat high temparature
rt700 vs srf
synthetic brake fluid hellcat
