Whipple bolt in?
Discussion in 'SRT Hellcat General Discussions' started by guitar2323, Jan 10, 2017.
  1. guitar2323
    guitar2323 VIP Hellcat Member
    Mar 3, 2016
    256
    84
    98
    Saratoga Springs,New York
    Does anyone know if the Whipple SC is a direct bolt in swap for the IHI SC?Warranties don't last forever and we all might need to think about what happens if this SC failure is widespread.
  2. G3SRT
    G3SRT Senior Hellcat Member
    Apr 23, 2016
    81
    64
    sounds/seems like it if i judge from the specs on their site- but it might be worth to ask them directly.
    • Most powerfuel highest flow supercharger system available
    • Up to 1" intercooler fittings
    • Massive 4.5L outflows 2.65L by 55%
    • No cogged noisy belt to fail on jackshaft, direct driven supercharger
    • Integrated Crusher 180mm inlet outflows smaller 90mm inlets such as other Eaton based systems
    • Massive Super Mono Blade flows over 2750CFM vs stock 90mm at 1150 CFM
    • Massive air-to-water aluminum bar-plate intercooler offers more cooling than any other positive displacement system available
    • Factory sensor compatible
    • Plug and play electrical connectors
    • Factory fuel rail compatible (including factory fuel psi dampener)
    • Stock fuel injectors compatible
    • High flow fuel injectors compatible
    • Adjustable idler system included
    • Flat torque curve for incredible acceleration
    • No internal engine modifications required
    • Unique oil level sight glass for easy oil level and quality check, no dipstick to bind or misread
    • Plug and play wiring with male and female connections
    • OEM quick connect fittings for easy installation, no ugly brass or steel fittings on the SC
    • Available in wrinkle black, polish or any custom color
    • Optional carbon air tube
    • Instant boost at the touch of the throttle
    • 3 minute pulley change
    Ref: 2015-2017 Dodge Hellcat Supercharger System
  3. Bigborehellcat
    Bigborehellcat My new 17 Torred Red HC Gold Supporting Member
    May 14, 2016
    35
    Chareston Wv
    Good info, makes me want to change out now
  4. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,644
    946
    Virginia
    That's a monster!
    Has anyone made the switch?
  5. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,614
    455
    368
    Henderson, NV
    Wonder how many psi that thing pushes? Also will need new PCM/tuner.
  6. LafnGas
    LafnGas Hellcat Member
    Nov 4, 2015
    49
    30
    18
    Long Island, NY
    It is indeed a direct replacement. Bolts right on and comew with a new throttle body and cold air intake.
    They sold a few and then went back to the drawing boars and redesigned the intake manifold and a couple of other parts. The 1st run with the new improvements are shipping this week and I have one coming for my 426 build.
  7. rayzazoo
    Nov 8, 2014
    3,498
    1,294
    668
  8. rgigowski
    rgigowski SRT Hellcat Supporter Gold Supporting Member
    May 19, 2015
    299
    122
    Dallas, TX
    oh my word.
