I run a 2.40 upper, stock lower, never saw a reason to install the lower, yes, heard plenty of arguments for better dampening, etc, however, my crank is just fine. New motor, stock lower with a pin.
I want all of us to be there to see what is what, 007 is got to be ready, I am not sure we are all ready. I want to take the boost record from you, I do,
Just so all know, TIM B. has some very quick hellcats, including 007. We are planning on meeting in Kentucky to run. I run with 007 and Phasthemi. It is my understanding that Tim was attending with a few cats, Curt was also going to go.
There maybe some technical difficulties with 007 and I am up in the air. Even though not stated, it is private rental for the quickest hellcats to see what is what.
Ok lots of the knowledgeable cats up in here!
Ok so... I live in socal and of course the crappy 91octane we get. My build will be next month and I'm running 275 upper and 10% lower with e-85 etc..
My tuner will be Josh at HHP and they said watch out for bad E 85 at the pump. So I stopped by a chevron that has the E 85 and the pump said ... from 51-85 and that is no good. HHP mentioned to buy a fuel tester to test the fuel at the pump but if it is no good than what do I do... pump it or not? Lol only 1 e85 pump around me.
Or is there a option to by 54 gallon drum or smaller to get the true 85?
Is there a additive or something to add to my fuel tank if I do get a bad batch of e85? Some kind of booster.
Thanks
So is there a additive or something to add to my fuel tank if I do get a bad batch of e85? Some kind of booster.
Thanks
Install a flex tune from Barth, Injected or Livernois, the flex tune automatically adjusts the tuning from straight 91 pump gas all the way up to E90. There are few threads on the Forum regarding this
