Why A/F 13.5:1 not 14.7:1?
Discussion in 'SRT Hellcat General Discussions' started by ciphros, May 21, 2016.
  1. ciphros
    ciphros Gold Member
    Mar 13, 2016
    1,115
    568
    613
    Tri-cities WA
    Just curious why the car runs rich even at steady state cruise? Assuming this is a designed safety for the motor, but curious if anyone has any info.
    Thanks!
  2. Tightlines
    Tightlines Gold Member
    Apr 8, 2016
    374
    164
    I noticed that as well. Here for the replies.
  3. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,776
    516
    423
    Henderson, NV
    You said steady cruise. I think 14.7 is idle a/f. Any throttle input will lower it.
  4. ciphros
    ciphros Gold Member
    Mar 13, 2016
    1,115
    568
    613
    Tri-cities WA
    Steady cruise should be stoic.
  5. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,776
    516
    423
    Henderson, NV
    Jus noticed mine is 13.5 at idle. Definitely different from other cars I've owned
  6. Jontall
    Jontall Silver Member
    Aug 19, 2015
    247
    42
    Because it's supercharged, it's tuned richer.
  7. ciphros
    ciphros Gold Member
    Mar 13, 2016
    1,115
    568
    613
    Tri-cities WA
    Still seems odd. I have had turbo cars that still run stoic at cruise, is this a "normal" thing for supercharged only?
  8. ciphros
    ciphros Gold Member
    Mar 13, 2016
    1,115
    568
    613
    Tri-cities WA
    Ok, thinking about this more, the only way I can make it make sense is due to the instantaneous response of the supercharger compared to a turbo increasing pressure over some small amount of time. Turbo motor would have time to adjust timing and a/f where supercharged may not. Anyone know if I am on the right track here?
  9. TNCHARGER
    TNCHARGER Gold Member
    Nov 19, 2015
    1,222
    485
    408
    I have had several Supercharged engines (after market) and all of them idled and cruised at 14.7. Not sure why the HC is different but may be an emissions issue but that is just speculation..
  10. ciphros
    ciphros Gold Member
    Mar 13, 2016
    1,115
    568
    613
    Tri-cities WA
    Would think emissions would be worse non-stoich. I did just read something about some supercharged motors needing to run a bit richer to idle well. Who knows. Just seems like we are burning excess all the time, mpg could get a tiny bump with a leaner mix.
  11. TallCool1
    TallCool1 Gold Member Hellcat Car Club Nat'l Hellcat Tech Advisor HCC Charter Member
    2,439
    831
    Pacific NW
    Forced induction engines increase cylinder pressure which can introduce knock. Stoic is optimum burn but isn't optimum performance and engines never completely burn 100% of fuel. 13.5...13.2 is the general range for safe peak torque at low rpm light load for normal gas . Then getting richer as you get closer to wot where af is changed to produce max torque over power (and vica versa, or both) depending on rpm, load and other factors.
  12. TNCHARGER
    Nov 19, 2015
    1,222
    485
    408
    I have never seen a supercharged engine that needed to idle richer (not saying there aren't some out there). At idle and cruise the engine is basically running as NA so nothing to compensate for.
  13. ciphros
    ciphros Gold Member
    Mar 13, 2016
    1,115
    568
    613
    Tri-cities WA
    So this is a supercharger thing then, since even at low rpm it has some ability to increase pressure? This is not true for a turbo, so just trying to understand the differences.
  14. ciphros
    ciphros Gold Member
    Mar 13, 2016
    1,115
    568
    613
    Tri-cities WA
    This is exactly why I am confused.
  15. ciphros
    ciphros Gold Member
    Mar 13, 2016
    1,115
    568
    613
    Tri-cities WA
    I understand it completely. I ran 22 psi all day long in the evo. But, at cruise I was 14.7:1, when the go pedal goes down and boost climbs, 10.5:1. I even went so far as to raise cruise to 16:1 for a while, but founder that stoich with higher timing Advance worked as well or better, and gave me a little more off-boost grunt.
