Widening Factory Rears-What's the Max?
Discussion in 'SRT Hellcat Wheels and Tires' started by Ohthatguy, Feb 10, 2016.
  1. Ohthatguy
    Ohthatguy Hellcat Member
    Feb 8, 2016
    50
    11
    When widening factory rear wheels 'to the inside' like Weldcraft does, what is the max width you can add without rubbing on the inside or having to then use spacers, 3/4"?
  2. YLWJKT
    YLWJKT Silver Member
    Oct 12, 2015
    411
    137
    Without spacers? Not a lot of room.
    With 305's on factory 9.5" wheels there's about 1.25" between the shock and the tire.
    At full extension the tire is less than 1/8" from hitting the inner fender well at the bottom.
    Different wheel but I had a set of '12 SRT8 wheels widened to 10.5" and 305's would rub occasionally even with 6mm spacers.
  3. 1FASTCAT
    1FASTCAT Rookie
    Jun 11, 2015
    1
    Port Perry, Ontario, Canada, L9L 2C9
    I widened my factory rims to 11" and have 315 on these rims. Kept the exact factory tire only instead of 275, they are 315. I did do a bit of wheel well work which cost about $400.00. this way I did not have to use any spacers at all. The tire fit under great and the car looks great. I actually got all the step by step procedure from a post on this very site. I am very pleased with the effort. The post was from early last year, 2015 I believe.
  4. YLWJKT
    Oct 12, 2015
    411
    137
    By "wheel well work" I'm assuming you mean the inside frame rail and sheet metal?
  5. 1FASTCAT
    1FASTCAT Rookie
    Jun 11, 2015
    1
    Yes, there is a triangular cover on the frame rail that is removed and moved closer to the frame rail. This gave me all the clearance I needed for the 315. Also some trimming of the plastic wheel well covers which was trimmed with the use of only a pair of sheet metal snips. If the shop you use is a good shop, they will make the job look as it was never touched.
  6. Ohthatguy
    Feb 8, 2016
    50
    11
    Good info-thanks. What brand of 315's did you end up fitting in there? The GY and Michelins run about 1" wider than Nittos.
  7. 1FASTCAT
    1FASTCAT Rookie
    Jun 11, 2015
    1
    I actually put on the same tire as factory only in a 315. I liked the look and the difference with the width looked so much better and although I haven't been to the track, it does seem to offer much better traction.
  8. Ohthatguy
    Feb 8, 2016
    50
    11
    Nice! How much clearance does it have? Could you go any wider toward the inside?
  9. Sepipr21
    Sepipr21 Silver Member
    Oct 17, 2015
    405
    48
    do you see any different in the way the car handles? grip? Any issues with widening the rims?
