Wider tires - Wheel flairs for Challenger (Pending?) - 20x11 rear 20x10 front
Discussion in 'SRT Hellcat Wheels and Tires' started by WormChizel, Nov 4, 2015.
  1. WormChizel
    WormChizel Rookie
    Dec 17, 2014
    10
    5
    Wasilla, Alaska
    Take a look at the 4-wheel drive 450hp Challenger that hit the Sema Auto show. If one looks closely, the wheel flares are definitely an add on. It looks interesting. It maybe that these can be purchased after market for our 2015 Hellcats. From the article, they are running 20x11 rims on rear and 20x10 rims on front. It may be worth waiting for if you like the look. 4-wheel drive challenger.jpg
  2. Garfield
    Garfield Hellcat Member
    Nov 1, 2015
    18
    Hope you understand the amount of work required to retro something like that onto your car... You will have to cut out the existing freshly painted sheet metal, otherwise you would be gaining nothing but looks and not be able to use a wider tire.. After cutting the metal will be exposed.. Then needs to be rolled and crimped and repainted then the new flares installed then color matched.. You are talking pretty custom metal work. Now you could always hack job it like you would a 4wd beater.. Sawsall the sheet metal and just pop rip it or screw the new flares on.. But I don't see many people doing that on a $65-70g car..
    Not trying to burst your bubble.. Just trying to inform you..
    Would be nice to be able to put real rubber in these cars though.. We would start talking low 8-9sec 1/4's then.
  3. WormChizel
    WormChizel Rookie
    Dec 17, 2014
    10
    5
    Wasilla, Alaska
    Yeah, I'm with you on that. It'll be interesting to see how they mounted them once they hit the floor.
    If it's a serious body work job like you suggest, I'll likely wave off.
    I could just do it Alaska style and Duct tape plywood ones on after using wood screws and Gorilla Glue to fasten them to the body;)
    That rear tire is the 'Fuse' in the powertrain. I would rather burn up a tire than blow a U-Joint.
  4. Garfield
    Nov 1, 2015
    18
    I joints are easy and way cheaper then a tire lol. Most times when building something to the extreme you purposefully pick a weak link.. Many times in racing or 4wheeling you pick the ujoint to be that link.. When using a flanged yoke it takes no more then a couple minutes to replace a $10 part.
  5. Carnage
    Sep 21, 2014
    12,107
    3,265
    823
    Houston, TX
    looks nice
bigger rear hellcat wheels
challenger 20 by 11 rear
challenger srt8 20x11 wheel
charger big tires rear
dodge challenger 20 x 11
dodge challenger hellcat 10 front tires
dodge challenger wide tires
