Will a Michelin Pilot Sport Cup 2 tire size 285/35ZR20 fit front?
Discussion in 'SRT Hellcat Wheels and Tires' started by Dragons90, Jun 25, 2016.
  1. Dragons90
    Dragons90 Silver Member
    Feb 23, 2015
    202
    82
    178
    Round Rock
    Or would going to a 265/35/20 be a better choice. I have Triumph's 20x10 on the fronts. appreciate the help.
  2. DGatzby
    Jan 16, 2015
    3,284
    1,680
    598
    Twin Cities, MN
    Depending on your offset, that may work real nice.
    Oh, I was reading that again, I bet Biz gave you enough room for those. We can do those on the 9.5 OEM wheels.
  3. pivotal
    pivotal Senior Hellcat Member
    Mar 24, 2016
    121
    35
    Silver Spring MD
    What's the offset of your front wheels? I'm running 285/35s on the stock wheels up front with a 1" drop without any problems.
    Matt
  4. Teo
    Teo Judge Yooper
    Jun 7, 2015
    886
    443
    Yooper Land
    I believe one member here has gone with 295-35-20 with 20x10 x 20 off-set wheels on all four! 285-35-20 should be a YES fitment for sure on the steers.
    And for "sometimes" track tires? Michelin PSS or ContiForceSport 5P's would be a reasonable choice, but NOT a hard core racing choice.
  5. Dragons90
    Feb 23, 2015
    202
    82
    178
    Round Rock
    Really appreciate all the feed back. This site has some great people on it. I am lucky that this car is just a weekend car. So going a little extreme with the set up is ok. The Sport cup 2 do not come in a 275/35/20 so it's go up to the 285 or go down to the 265. What would you guys do??
  6. Teo
    Teo Judge Yooper
    Jun 7, 2015
    886
    443
    Yooper Land
    I always try to stay as close to OEM diameter (28.6) size for the steers that I can find. Steers are always the challenge IF you wish to lower your ride? Drives can be beefed up depending on suspension clearances. -1% to + 3% on OD size should keep the putter happy! :cool:
  7. Dragons90
    Feb 23, 2015
    202
    82
    178
    Round Rock
    Going with the Biz's set of 20×10 up front and 20x11.5 in the rear running 315/35/20's Nitto NT05's in the rear
  8. Dragons90
    Feb 23, 2015
    202
    82
    178
    Round Rock
  9. Teo
    Teo Judge Yooper
    Jun 7, 2015
    886
    443
    Yooper Land
    Bizmark is a GREAT guy!! Trust in his advice! He will insure you are set-up for the most amount of future tire sizes possible for your rims.
  10. DGatzby
    Jan 16, 2015
    3,284
    1,680
    598
    Twin Cities, MN
    Do the 285/35, IMO.
  11. Dragons90
    Feb 23, 2015
    202
    82
    178
    Round Rock
    DGatzby i think that is the way to go
  12. TrackDay
    TrackDay Gold Member
    Mar 28, 2015
    1,112
    319
    Sorry for the delay, but 285/35 is definitely the way to go. I had the PSC2 tires in that size mounted up front on 10" wheels with a 15mm offset. I've since gone to 295/35 Pirelli Corsa as was mentioned above.
  13. carcass
    carcass Silver Member
    Sep 7, 2015
    857
    264
    173
    What's that about plus or minus od for a happy computer?
    And is a 285/35 better than a comparable compound tire in 275/40?
    Is the small gain in width worth the loss in height?
    Or is going to a 285 simply due to a better tire option like the Michelen?
  14. Teo
    Teo Judge Yooper
    Jun 7, 2015
    886
    443
    Yooper Land
    Being aware of your + or - % from a OEM dia. is to NOT cause an ABS confusion with-out having to re-program your computer's OEM tire size. A -1% from a 28.66 (275-40-20) oem dia is approx. 28" overall dia. while a +3% is 29.5" overall dia. and may rub?
    IMHO ---- Michelin Pilot Super Sports hands down are the BEST street tire. Conti's DW's are a close second while still staying with-in OEM specs for a 106YXL rated tire. Nitto's 555G2 are 106W rated, so continued high speed runs over 168mph would NOT be a good idea.
    As to width gain? IMHO more rubber on the road is always better! Especially IF one goes with a square set-up for road courses! My next set will be 295-35-20's in MPSS or Conti's 5P with 20x10 with 20mm offset on all (4) unless I lower my ride and then 295's may NOT fit the steers?(full lock to Lock) under hard conditions.
    I currently run Conti DW's 275-40-20 (106Y XL) on the steers with 20x9.5 x 18mm. With Conti DW's 315-35-20 (110Y XL) on 20x11 x 21mm for the drives.
    If you are considering 285-35-20's ---- They may????? be OK (face thread support contact) on our 9.5" OEM rims, but for me I would NOT run any road course with less than 10" wide rim, even on a 285 tire.
    Here are charts to visualize oem to proposed sizes. Rim & Tire Size Calculator. Custom Offsets
    Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
    Visual of 315-35-20 on the drives Album: The Fastest Color in the World!
    And a recent wheel review Axis Model Two
  15. pivotal
    Mar 24, 2016
    121
    35
    Silver Spring MD
    Great info Teo. I'm running Michelin Super Sports - 285/35 up front and 295/35 in back on OEM wheels. My car is lowered about 1.25" up front and 1.5" in back on the KW sleeve kit and I have no issues with rubbing. As mentioned, Michelin makes a very good street tire and I would highly recommend going as wide as your suspension setup and budget will allow.
    Matt
super sport cups 2 hellcat
