Will the 215/65/17 fit on the Hellcat?!
Discussion in 'SRT Hellcat Wheels and Tires' started by FINALLYSATISFIED, May 11, 2016.
  1. FINALLYSATISFIED
    FINALLYSATISFIED Silver Member
    May 23, 2015
    573
    134
    San Diego, CA
    Long story short they are trying to put the OEM stock rim size from the base model on my Hellcat until they fix my rims. They are leaving the OEM stock Hellcat rim/wheel on the front and repairing the 2 rears. Will this work?!?!
  2. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,304
    808
    Suwanee, Georgia
    215 in the rear?
  3. FINALLYSATISFIED
    May 23, 2015
    573
    134
    San Diego, CA
    Yes
  4. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    671
    224
    No 17" rim will fit over stock front brakes and will interfer with sway bar link in rear.
  5. FINALLYSATISFIED
    May 23, 2015
    573
    134
    San Diego, CA
    These are just for the rears.
  6. paul suloff
    Aug 25, 2014
    671
    224
    Depending how wide they can hit sway bar link in back. 9" wide should work. If tire dia matches should be OK as a temp spare.
  7. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,304
    808
    Suwanee, Georgia
    Actually 17" rim fits fine if you raise the car from the lower control arm.
  8. FINALLYSATISFIED
    May 23, 2015
    573
    134
    San Diego, CA
    I'm suppose to have these for the next 5 days on the rears.
    Tire size is 215/65/17 that is currently on it. If I will end up getting damage from these I will give them a call for someone else.
  9. paul suloff
    Aug 25, 2014
    671
    224
    Should be fine for a few days. 215 is .75" shorter and could set an ABS light but doubt it. Not too worry.
  10. FINALLYSATISFIED
    May 23, 2015
    573
    134
    San Diego, CA
    Thanks
  11. Tire God 2.0
    Apr 24, 2016
    332
    82
    I would assume that this fitment would be very unsafe at highway speeds handling and stability wise. I would just not drive it or very little.
  12. rwhite692
    rwhite692 Gold Member
    Jul 17, 2015
    646
    257
    Central Valley, Northern California
    Unsafe at highway speeds...really? the same wheel and tire package, is on the base or R/T cars. If it clears the brake package without issue, its perfectly safe on his car at highway speeds.
  13. Tire God 2.0
    Apr 24, 2016
    332
    82
    Not when you have a 275/40-20 on the front. Not a good idea. But it might be your only option till you get the problem resolved. Mixing sizes like that will make the car unpredictable. When you replace two tires you want the new on the rear for the same reason. To prevent hydroplane/fishtail. Ever seen a drag car with skinnies on the back? Me neither haha
  14. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,304
    808
    Suwanee, Georgia
    So it means we shouldn't run 275 on the front and 305 in the back?
  15. Tire God 2.0
    Apr 24, 2016
    332
    82
    No, wider on the rear is good. His problem is he is running stock on fron and tiny on rear.
