Will the cobra 17s fit like on previous srt
Discussion in 'SRT Hellcat General Discussions' started by Nycsrt, Jan 7, 2015.
  1. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    806
    563
    For drag racing purposes ??
  2. Noquarter
    Noquarter Gold Member
    Nov 19, 2014
    777
    249
    Columbus, OH
    Was wondering the same...
  3. paul suloff
    paul suloff Gold Member
    Aug 25, 2014
    753
    260
    I tried a 18x10.5 wheel on the rear and it hit the sway bar. A 17x9 might work as mention here before, but that's too narrow for a 305 tire. I'm not sure if previous SRTs had the same sway bar set up? I'm assuming so and that's why the narrower wheel works. Looks like a 20x10.5 is the widest.
  4. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    806
    563
    It's a 275 tire
  5. Noquarter
    Nov 19, 2014
    777
    249
    Columbus, OH
    Is there a 9.5 svt rim out there? 9.5 is the stock srt rim.
  6. paul suloff
    Aug 25, 2014
    753
    260
    You can run a 275 tire on the 17x9" rim. Most run a 275 on a 10" rim. I don't think that's gona wide enough to solve traction issues at the track. The 305 is going to get the most tire on the ground with a 10.5 rim.
  7. Top Cat
    Nov 26, 2014
    1,925
    1,087
    768
    Doylestown,Pa
    You just can't jack up the car and place a wheel on to check for clearances, it must have the tire on and down on the pavement to set the suspension , much different hanging in the air, a 17x 9.5 to 10.0 should work, but I would recommend borrowing someone's and test before buying a set.
