Will "the new" Nitto 555 G2 rub
Discussion in 'SRT Hellcat General Discussions' started by SUPERCOOLSRT, Apr 27, 2016.
  1. SUPERCOOLSRT
    SUPERCOOLSRT VIP Hellcat Member
    Nov 18, 2015
    128
    66
    98
    Huntington Beach, ca
    wanted to put a set of Nitto 555 G2 in back only
    305/30/20
    Will they rub?
    I thought I read in a thread " that I could not find" just confirming before I purchase tomorrow
    Thanks gang
  2. SUPERCOOLSRT
    Nov 18, 2015
    128
    66
    98
    Common someone
    I know u have the answer need to order today
    Help! Will the 305/30/20 rub on the hellcat charger
    Thanks in advance
  3. Aarcuda
    Aarcuda Gold Member
    Oct 22, 2014
    1,515
    488
    408
    The Boonies
    will the tires rub?
    Will David ppropose to Jeanette?
    Will old man crowley close down the mill?
    And what about little joey???
    Stay tuned next week for more exciting adventures in "As the wheels turn"
  4. COL P
    COL P Hellcat Member
    Feb 25, 2015
    64
    4
    What tire are you pairing this with in the front? Are you using stock rims? Couple of things to think about If your staying with the 275/40 in front, just understand that this is a 305/30 aspect tire (not 35) and it has a diameter of 27.25" versus approx. 28.7" for the 275/40. So the rears will be significantly smaller than the fronts (1.5" in diameter). The 295/40 version of this 555 G2 has a closer diameter size (29.3") and is around 11.85" wide (although the 305 is .5" wider).
    Room for thought. Regardless, if you go with the 305's it would be interesting to know how they fit. May be another option to add to the "tire" arsenal.
