ZL1 Vendor Front Rock Guard Install
Discussion in 'ZL1 Addons' started by VanishingPoint, Feb 25, 2015.
  1. VanishingPoint
    VanishingPoint Silver Member
    Jan 6, 2015
    923
    235
    Somewhere, Texas
    Purchased the much needed rock guards, front & rear from ZL1. They are well made, and easy to install. The only tool you will need is a 7mm wrench/socket with enough room to clear the front tire. Also a rag to clean, and maybe some rubbing alcohol.
    Here is a pic of the front and rear guards:
    [​IMG]
    1. Remove rocker guard bolts with 7mm wrench:
    [​IMG]
    2. Pull gently to pop these tabs. Note you must push as you pull a little due to the middle tab. Take your time with this, or you will tear the wheel well plastic.
    [​IMG]
    [​IMG]
    3. Clean the area, especially the fender lip to remove all debris and wax, finish up with a few swipes of a rubbing alcohol to allow the 3m tape good purchase.
    4. "Start" the top of the 3M tape strip but DO NOT REMOVE YET; just make it so it is easy to pull off later. All you are doing is getting it ready to remove, once the guard is installed. You will thank me later for this.
    5. Comparison shot:
    [​IMG]
    6. Examine this picture:
    [​IMG]
    Note, the top bolt goes on the outside of the guard, and the lower bolt the inside. I found it a bit easier to have the bolts already pre-set in the guard making it easier to squeeze into the fender. YMMV. You may have to pinch the plastic wings as they want to bow during insertion, preventing you from getting them in the fender/rocker.
    A reminder of what I am speaking of:
    [​IMG]
    Once in, proceed to cautiously tighten. I found the beast of the bunch the lower screws, and you may find that you will have to get a digit into the fender rocker area, to apply pressure *behind* the clip to ensure the threads grip as you tighten, and it does not spin while you tighten.
    This may be no small task depending on your big, ruffian, ham hands, and it was required for me on both sides and you DO NOT want to strip this little plastic bugger.
    Get them on firmly, and there may be some play (I did not want to risk over tightening them) but it should hold securely.
    Once in place, line them up on the fender, the top edge just to the limits of the outer part of the fender (I wanted as much tape to pain as possible). Get it exactly where you want, as you will really only get one good shot at this due to the mad-sticky tape.
    Give one or two more turns to tighten, check alignment again, and pull the top of the guard back, and begin the removal of the 3m red tape shield. The 3m is potent, so once it hits metal-it is on it.
    Once clear, press it firmly where you want it, and hold for a few seconds, and rub along the edge to ensure a solid tape to paint connection.
    You are done:
    [​IMG]
    The job with this guide is really a sub-10 minute piece. It took me maybe 25 minutes due to having to find the right wrench, not being sure what would do what and how it went there, etc.
    To be 100%, I think you are madman if you don't purchase these and install them, your car's flanks will be tore up and look like a bird shot blast from a shotgun in a year. The front summer tires pick up, and throw everything-and guess where a bulk of the debris is going (I already have a chunk of the clearbra with a rock divot in it because these had not been installed yet-look to the bottom right door clear bra line-the dark spot-easy to see because the car has a film of south Texas dirt on it).
    The guards are subtle and not "4x4" as well.
    Looking forward to installing the back ones now.
    • Useful Useful x 9
    • Winner Winner x 2
  2. Paladin06
    Sep 3, 2014
    4,701
    1,853
    San Tan Valley, AZ
    Great DIY.
  3. B5 Blue
    1,745
    Nice write up VP
  4. skylane765
    skylane765 Silver Member Hellcat Supporting Vendor
    Jan 27, 2015
    249
    50
    Thanks for the write up, I am good with my hands, but not very good at writing up info.
  5. BlackCat15
    BlackCat15 Silver Member
    Dec 9, 2014
    161
    28
    Ontario Canada
    I need these guards for the '15 Charger. Anyone in the San Diego area able to drop by so they can get measurements? I'm sure you'll score a free pair for the trouble.
  6. skylane765
    Jan 27, 2015
    249
    50
    Yes and also get free jack pads and we will make splitter washers for your Charger!!
  7. skylane765
    Jan 27, 2015
    249
    50
    You were the first person we made the rear guards for. You do have the wrong push pins, we have the correct one to send you.
  8. F6F
    F6F BANNED
    Dec 19, 2014
    2,089
    1,014
    668
    Team Hellcat, MD
    I just bought them, thank you
  9. adub
    adub Hellcat Member
    Oct 30, 2014
    45
    Houston. TX
    Can you post a few shots of the car with these installed?
  10. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
    70.196059, -148.559760
    Very nice write-up. Thanks for taking the time to document this. Please consider posting this to the WIKI section of Hellcat.org...
  11. F6F
    F6F BANNED
    Dec 19, 2014
    2,089
    1,014
    668
    Team Hellcat, MD
    I do not see the rear ones on your website. Can you tell me how much? I installed the front ones today, EXCELLENT PROTECTION !!!!
  12. F6F
    F6F BANNED
    Dec 19, 2014
    2,089
    1,014
    668
    Team Hellcat, MD
    Hey Vanishing Point, did you install the rear ones?
  13. skylane765
    Jan 27, 2015
    249
    50
    we will have the rears on our site in a few days. We do have them at Amazon right now or you can email or call us.
  14. F6F
    F6F BANNED
    Dec 19, 2014
    2,089
    1,014
    668
    Team Hellcat, MD
    Can you send me the Amazon link?
  15. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    701
    154
    McKinney, TX
    I installed the front rock guards today. Easy install.
    Tips:
    Working with the tape isn't very tricky. Just start peeling the edge of the tape to give you an edge to pull. Then start the 2 screws a few turns. Pull the tape strip off while holding the guards in the correct location. Press them in place and tighten up the screws. Quick and simple.
    Gripes:
    The guards have a "Made in USA" sticker on them that's on the outside of the guard, so it sticks half way out when installed on the car. Remember to remove the sticker before you install or it'll be difficult to remove afterwards.
    The outside edge of the guards appears to be hand cut and the edge isn't cut very cleanly. I had to file it to make it look like it didn't receive some road rash.
2015 zl1 rock guards
challenger hellcat rock gaurds
front rocker guard for challenger
hellcat challenger zl1 rock guards
hellcat rock guards
hellcat zl1 rock guard install
installing challenger zl1 stone guards
zl1 rock guards for hellcat
