1 - 3 of 3 Posts
· HOTY Winner
Hey guys,
Not looking to debate over this, just posting info for the greater good, knowledge is power baby!
Spent a little time digging into a lighter front sway bar to shed weight off the front of my HC Challenger
1320 Front Hollow Bar
Part # 68184221AB - $127.40 1/12/2022
Front Bar Frame Bushings (2)
Part # 68312673AA - $22.71 each 1/12/2022
Weights that I found on y0utube
Bar, two nuts, end links weigh 10 lbs 13.5 oz.
All Heat shields and screws 2 oz.
All Bar brackets and bolts 1 lbs 11 oz. (13.4 oz. per side he said in the video)
Everything 12 lbs 13.4 oz.
I have been told the everything for a 2015 HC Challenger is 25 lbs - Solid 34mm Bar
Worth it or not, 12lbs 2.5oz. reduction from the front of the car.
Or you can take yours off for track days and lose 25lbs on front.
One thing I have not found is the diameter of the bar, if you know it, please post it up in this thread.
Reactions: AJ4Life
2019 Redeye
I just. Removed mine altogether
if your straight lining the car .
i think there are several here that drag race t.hat just removed them.
something to consider if your not running the twisties
· HOTY Winner
I drive the car to events on highways, 3 digits on the clock.... I will just remove for track, but keeping on all the time for street driving.
I am leaning towards the larger bmr ones, was considering 1320 front bar but nobody knows the diameter. I really hate to go down in size either.
Reactions: White Trash
1 - 3 of 3 Posts
