1 - 9 of 9 Posts
I have searched good and everywhere I can find. Nothing came up for a 2.65 stock lower without an adjustable tensioner. Anyone willing to share the belt they use with a 2.65.
my guess K100570HD or K100564HD
I use the K100572HD with an adjustable tensioner (2.65 with stock lower) because I run a 2.85 on street (without tensioner).
I have that belt now and pulley. I am looking at running the 2.65 full time so trying to stay away from the tensioner if possible.
· Super Moderator
Hi Jon I think you use E85.
@JP9 is giving correct info for the belt K100572HD
AAD or Bwoody tensioner should be used and you should also be pinning the crank.
Linda :)
Discussion Starter · #5 ·
Linda :)
Linda- crank is pinned. Vortec and I had a New Years party and did that and axles.
I have seen some at the track without the idler. I messaged one of them from the local track but he didn’t know his size and wasn’t able to go check.
I may end up doing a lower instead of an idler if that is what it comes down to. For the cost of the idler I’d rather just make more power 😊 I’m regretting not setting my fuel system up for more.
Yep I have a drum of e85 next to the car
Jon, did you try out the K100570HD for the 2.65? Curious to know if it worked and where the tensioner landed.
1 - 9 of 9 Posts
