If I am not mistaken 2018 only has EPS on wide body models
You are correct .If I am not mistaken 2018 only has EPS on wide body models
Yup, without all the important info, it's just nonsense numbers.Seems like some random numbers that don't compare.
Wouldn't you also need to post the density altitude and temperature for when each test was ran to be somewhat comparable?
I mean I could test one here at 110 degrees F and one at night at 55 degrees F in the same day. I'm sure I could get a bigger split than this.
Ok then post the DA, weather, type of dyno, etc for each & every pull with sheets.
Bingo, you are not mistaken.If im not mistaken the OP is not just the average dude.![]()
Oh wait, it's true if it's on the internet...
Chrysler Test Center Test Cells C07 and C08.Where did you get this info from?
R.K.
Ray, if those are tests using 91 octane, will it allow a bit more timing (power) if we use a solid 93 octane?Chrysler Test Center Test Cells C07 and C08.
SAE J1349 testing standards (SAE J1349 standard of 77°F (25°C) day with 0% humidity and a barometric pressure of 29.234 in-Hg (99 KPa)).
These are the SAE power certification test results conducted about 1 year prior to release of the product to market. The public can purchase the dyno sheets at sae.org.
A nice article from Roadkill when the Demon engine was tested.
Dodge Shows Us The Demon Engine On The Dyno - Roadkill
91 octane are the tests except for the Demon 100 octane test.Ray, if those are tests using 91 octane, will it allow a bit more timing (power) if we use a solid 93 octane?
Running hard and hot it gave me misfire codes on our road course, with 93. Added octane booster never have a problem since and it seems to eat stuff up on the 3/4 mile roll basically. So it runs strong and consistent on a good diet. FYI it recorded 670/666, with the DA of about 700'.
Oh no. That can happen, I have had it happen, so never start a session with less than 3/4 FULL. It runs great on 93, I am good with it.Interesting... I would have thought 93 would've been perfect. Maybe its the RON VS MON makeup of that fuel?
Sure it may be 93, but that rating is an average of the two ratings.
I notice that race gas actually lists the average octane and the two ratings separately...
At first I thought maybe your car might be fuel starved when you're loading up the Gs cornering and getting the misfire.
BTW, nice engine hp/tq numbers!
