1 - 8 of 8 Posts
I got a 2015 charger hellcat that snapped a rod and blew a hole in the block, can I buy a newer motor from a 2016+ car and drop it right in? I will be reusing the supercharger and heads and everything else that's not destroyed.
· Administrator
Yes you can use a newer motor. Especially a 2016 as there are no changes between the two years.
· Administrator
Well, won't you need a 2015 or 2016? Didn't they go to different intake sensors in 2017?
Since the op stated he was going to use his blower one would think he would be using his intake also. If the intake tube is being reused then a 2018 motor and blower could also be used.
1 - 8 of 8 Posts
