Hi guys and gals. First time poster here.
I've got a 2016 challenger hellcat that I purchased already modified 2 years ago and had it retuned by a local/reputable performance shop. It's tuned on e85 and has multiple modifications to justify this fuel. Anyways, recently I've been having parasitic battery drain issues and I've already replaced the battery. About this time the active exhaust valve on my borla exhaust fell off the bracket and was throwing codes. I decided I'd delete the exhaust valves using zautomotives kit (hoping to help the battery drain issue) and that code went away but alas I'm still having battery drainage issues. Then a new code popped up about the intercooler water pump voltage out of spec. I researched that and cleaned the terminals thinking it might help and at first it didn't, but on the way to the shop after 20 miles my temps finally started to drop well below ambient (I've got the killer chiller system) so I thought, hey great maybe that'll fix my voltage issue. But the shop said they've still been having the issues and they have a slew of bcm codes, chassis codes etc. Does anyone have any ideas about what could be causing this problem? Both me and the shop are stumped and they are suggesting me to take it to the dealer to have them scan the codes more thoroughly. Thoughts?
Codes currently in the system:
B1208-11 - Anti Theft indicator short to ground
B16AB-15 Trunk lamp control circuit short to battery/open
B1751-15 - Couresty lamp control short to battery/open
B18BA-11 - Window control short to ground
B210C-16 - Battery voltage below threshold
B2199-16 - Battery voltage below threshold
B21DD-16 - System Voltage below threshold
B21DD-84 - System voltage below range
B21DD-85 - System voltage above range
B25B4-2A - Pawl switch stuck
B2860-15 - Door ambient light control short to battery/open
C121C-00 - Torque Request Signal denied
C2129-16- Battery voltage below threshold
C212A-16 - System Voltage below threshold
P0EA7 - Aux Cooling Performance
P1009-00 - Humidty Sensor Module
P1400 - Aftermarket Calibration
P1DD2-00 - Torque Request Signal from TCM denied
U0001-00 - CAN C Bus (stored)
U0121-00 - Lost communication with ABS module (stored)
U0140-00 - Lost communication with BCM
U0147-00 - Lost communication telematics gateway
U0415-00 - Implausible data rec'd from ABS
