I installed the current generation Tazer and it does what it says it does. Mainly wanted it for LineLock. Also thought I’d install a front camera so I ordered Zautomotive’s AV harness and extension cable. Installed a new camera up front and still searching for best routing through the firewall. I wanted to test the camera out so hooked everything up. No work!
Quite possibly die to my not having things set up correctly so here are some feedback and experience with ZAutomotive so far.
1. Their instructions are crap and read like ”how much information can we cram onto the least number of pages. It’s disjointed and not well laid out. Spend som time and organized the instructions better. Maybe have separate ones for each generation/model.
2. Under the radio Nonlive menu, I enabled cargo camera.
3. After using ZAutomotive’s “Text” support which means next day response, They had me check under the Live Menu and set my radio to the 8.4 UConnect. I did that. Text support dropped off….
No camera, no video although I could see the cargo camera option in the “Controls” app on the UConnect.
I did all the reboots, sleep cycles etc… still no video…
I test the power going to the camera and have 12 volts.
Reached back out the the “Text“ support and no response….
About ready to give up on the this set up and look at other options unless anyone has some tips.
This is the camera I’m using:
PARKVISION Mini Car Side View Camera/Rear View Camera/Front View Camera with Rotatable 360°Lens,Easy Installation Without Drilling, Upside Down Flip Image Function Without Guideline.
by PARKVISION
Learn more: https://www.amazon.com/dp/B07V371Q49/ref=cm_sw_em_r_mt_dp_MHF3V66WRPD53SAS5XF8?_encoding=UTF8&psc=1
The only thing I haven’t done is cut the blue wire on the camera to switch it from back up to front mode. I figured I didn’t need to do that until I know it’s working. It’s getting 12v constant power so should be sending video out….
Please share any feedback you might have…
by PARKVISION
