Hey guys have any of you noticed this? I’ve been driving my car pretty hard, went to check my oil and it was a quart low is this normal? The oil was changed at 2750 miles and now has 5200. No low oil light came on. Do you think I harmed my engine?
My car burned oil for the first 6,000 miles- then it stopped almost completely
Is that normal? You have a RE?My car burned oil for the first 6,000 miles- then it stopped almost completely
I got the car with 1800 miles on it. It had fresh oil. Just changed it at dodge dealer at 2750 just to have it done figured it couldn’t hurt.Did you personally verify the oil level was ok at 2750??????? Why was it changed so soon?
Ok awesome thanksCats can burn up to a quart every 2500 its normal. Just top her off. the` more you break her in the less you burn.
The mechanic gave me just enough but not extra. Yes I checkedDid you personally verify the oil level was ok at 2750??????? Why was it changed so soon?
Oh so in the break in they consume oil? Also what oil do you use? The dealer used penzoil buy I topped of with Mobil one. That’s fine right ?Cats can burn up to a quart every 2500 its normal. Just top her off. the` more you break her in the less you burn.
Yes . Breakin they consume some oil.Oh so in the break in they consume oil? Also what oil do you use? The dealer used penzoil buy I topped of with Mobil one. That’s fine right ?
Anything 0w-40 full synthetic will work just fine. I personally use amsoil its the best out there. And yea later on with more miles your car will burn less and less. Some say it completley stops but I still see a little after 3k miles, and I have around 25k miles on my cat. Nothing to stress about just check it when you can and maybe invest in a Catch can to catch any residual blow bye. I catch a lot!Oh so in the break in they consume oil? Also what oil do you use? The dealer used penzoil buy I topped of with Mobil one. That’s fine right ?
During break in the engine can consume some oil.Oh so in the break in they consume oil? Also what oil do you use? The dealer used penzoil buy I topped of with Mobil one. That’s fine right ?
What oil do you use and where do you get it?During break in the engine can consume some oil.
But even past break in an engine can use oil depends upon the engine and how it is used. Lots of idling or the flip side lots of high RPMs can have oil consumption go up.
Ideally you should top up the oil with the same oil that is in the engine. But in an "emergency" in this case Mobil 1 0W-40 is "probably" ok.
But there is no good excuse for getting caught out like that and having to use some other oil.
You need to carry a quart or two of the right oil in the car so you have the right oil in case you need to add oil. I get a plastic tub large enough to hold a couple of quart bottles of oil, some paper towels and other items.
For a new car you need to at first check the oil often. At the start of the day's usage and after every fill up. Once you have a feel for the engine's oil consumption you can dial the oil level checking back some. At some point some miles after the nominal break in miles I'll check the oil level after every fill up. The engine is up to operating temperature and the car is level so the oil level check delivers accurate and repeatable results.
