I totally agree, to do it right you need to decide whether you want to go straight or around corners. For the most part I think these cars from the factory such at both. These twist and flex under load like crazy, and that’s what causes stuff to fail. My cars were setup more for street/corners. There are no short cuts if you want it right. I gotta believe some under car go-pros on a stock car with DR on a prepped track would make your hair stand on end! LolYep, and none of those dragpaks and drag cars have lowering springs on them. I built drag chassis for a living for about 10 years of my adult life. In addition, the entire rear geometry is configured for the specific wheel and tires, thus allowing efficient power delivery and weight transfer. Adding lowering springs changes the axle's angle, which is what wears out the axle boots on the IRS. You can of course reconfigure all your lower geometry to match the new springs, but that's like a $6,000 job that nobody who price shops lowering springs is ever going to pay.
And, just because drag cars sit low doesn't mean the shocks don't have a LOT of travel... as you can see it trying to stick out of the rear fender on the last image. Street cars are not drag cars, no matter how much folks try to pretend otherwise. Lowering springs makes Hellcats slower.
