Tip: If you happen to drop one of the screws, or, a T25 socket into the front belly pan which is VERY easy to do (ask me how I know ) !
You should not have to remove the front pan which is a total PITA ---- simply remove the rear pan under the oil pan which is simple with just the 4 bolts and with a flashlight and a magnetic long handle tool look inside the front pan and fish around if needed ! I found mine without needing the mag tool.
