I'm starting to wonder if my stock A8 Cat has the 3.70 gear vs the 2.62s? It's a 2019, so do all 2019 and up year models come with this setup or is it optional? I bought it used a while ago.
You can feel a lot of torque in the first two gears which are critical for good 0-60 and 60 ft times in which neither I'm good at right now. I definitely have to ease into the gas pedal slowly or too much throttle would be some spin for sure.
Of course practice makes perfect but can still be quite difficult to get the power down to the point where I still have to drive with an egg under my foot launching this monster.
Even having 20x10.5 replica wheels with 305-35-20 Nitto drag radials in the rear and the car still struggles for traction down low.
I'm curious to know if I actually have the 3.70 gear as pictured as opposed to the regular 2.62 and if anyone else has it as well, what remedies have you used for better traction?
Switch to different gears?
Change the tire setup to stickier rubber than Nittos to lay the power down better?
Do suspension upgrades?
Launch in 2nd gear?
Any actual benefit to 3.70? Around 50 mph and above it hooks and continues to pull strong but I can only imagine how the power of the Cat feels below 50ish mph.
Launch in 2nd gear?
