1 - 20 of 39 Posts
21' Hellcat Redeye Widebody
Does anyone have any pictures of their Hellcat Widebody with 305/45-20’s Mickey Thompson ET Street S/S’s on their stock rims?
I would like to see how they look and fit.
They say they should fit, but I can’t find any definitive proof if they really work or not.
Any help is appreciated. Thanks.
21 Camaro ZL1
I had one of the shop owner I was working with of his 2020 Charger WB with the ET street SSs on his stock wheels. They looked a tad meatier than stock tires and fit perfect., He LOVES them for stock street driving,. The ET street SSs are the same compound as the R and they hook like glue from a dig or roll. I had the 17" ones on a racestar on my 2021 Charger HC and they were awesome. Tough to balance but worth it. I dont have the pic anymore on my phone, but what you are looking to do will look awesome and hook like a monster.
21 Camaro ZL1
Oh and yes they fit, and dont rub at all. I sold my 21 HC and got a 21 ZL1 and was going to get these in that same size for my stock rear wheels as well. I know ZL1 guys that run them too and they are great for the camaro as well.
I also seen them on a friend’s Hellcat mounted on the standard wheels, no bulge at all, sidewall was straight in line with wheel edge.
I will be purchasing a set when my stock tires need replaced.
Love to see pics. Considering a set to go on my stock height ‘15 Chally HC with 20x11 HR5’s. They still can’t hook as well as 18’s or 17’s though, right?
Reactions: Unholy707
‘16 A8 Shaker
Found it strange the 20’s are considerably more expensive than the 17’s when the 17’s require more material to manufacture and work better
New intro with lack of proven demand?
I've heard a few folks move on to the ZL1 from the Hellcat. Do you like the ZL1 much better? Sometimes I wonder other than the handling if the ZL1 is still better?
‘16 A8 Shaker
I think they have been out as long as the 3402?
Mickey is so weird. The 3405 that the op is asking about (bigger tire than the 3402) they measure on a narrower rim. So it ends up advertised as a 10/31. The 3402 is advertised as a 11/28.5
· Supporting Vendor
Challenger SRT Demon
Our data is showing the maximum recommended tire height for your vehicle at 28.4" on the front axle and 29.82" in rear, although our specs are a bit on the conservative side the 305/45 would be about an inch taller in the sidewall than the stock tires, at 30.8" tall, they are a little outside of our fitment range but they may still work. They are a good fitment to the wheels as a 305/45R20 is recommended on wheels from 9"-11.5" wide.
With this said, there are not many options built in the 305/45R20 size option.
We are happy to help further, pm on the way.
Seems its an inch larger than recommened for the rear axle. 29.8 vs. 30.8.
I imagine the taller sidewall would make the tire squirmier through the turns but Im certain you realize that.
1 - 20 of 39 Posts
