1 - 9 of 9 Posts
I finally got one mounted to check the fitment; 315/35x20 Michelin Pilot Sport 4S on a Factory Repro FR70 10 1/2" wide, 25MM offset. I have at least 1/4" on the RR and 3/8" on the LR. My tightest spot was 3 o'clock on the RR and 9 and 10 on the LR. I wanted the 315 since the diameter is closer to the front tires; 275/40x20. I bought some 6MM spacers, but doubt I will ever need them. I am happy!!!!!! Tires 1.jpg Tires 2.jpg Tires 3.jpg
Yeah, I would think so. After reading dozens and dozens of posts, a lot were worried about the sectional width of the 4S being wider than other brands?
I finally got one mounted to check the fitment; 315/35x20 Michelin Pilot Sport 4S on a Factory Repro FR70 10 1/2" wide, 25MM offset. I have at least 1/4" on the RR and 3/8" on the LR. My tightest spot was 3 o'clock on the RR and 9 and 10 on the LR. I wanted the 315 since the diameter is closer to the front tires; 275/40x20. I bought some 6MM spacers, but doubt I will ever need them. I am happy!!!!!! View attachment 571437 View attachment 571438 View attachment 571439
I'll be very curious to see how these handle a good bump in the road because that's way too close for comfort in my opinion.
With that level of tight fit, how does it work when you bind the suspension? Rubbing?
Discussion Starter · #7 ·
No, that is the closest it will be. When it goes down or up, the gap opens up more. Secondly, if I worry anything it Knuckle Gap.jpg will be up front by this bolt! Stock tire and wheel, and the same on my 392 Charger.
How are your 0-60 times with the 315 PS4s I’m literally doing that this week but was thinking of just going with the 305
Discussion Starter · #9 ·
Still waiting to get the other mounted. When I went to the Firestone store, a clerk told me they use beads inside to balance the assembly..............I'm guessing that they will still spin from 0, but I'm hoping to get down to 40 for the dig.
1 - 9 of 9 Posts
