1 - 4 of 4 Posts
Hello All. Been searching trying to find an acceptable offset range for a 345/30r20 but as always offsets seems to be a crazy coveted thing.
I want to get a set of Weld S71 17s for the track and was thinking of getting a matching setup of 20s to run with them on the street. If I was a little more serious I would run the skinny on the front but only swapping the rears for now. Issue is Weld doesn't have recommended sizing for anything greater than 11" wide.
My searching I've seen everything from 20x11.5 to 20x12.5 but again nothing on offsets. Some guys like a little tire poking but I'd like to keep it flush at max without having to do any work to the liner like I did my last Challenger (20x10.5 +23 315/35r20).
Can you help?
'19 Challenger HC RedEye Widebody
Can you help?
I bought my REWB used from a dealership, and it had Stance brand wheels with 335 on the front & 345 on the rear.
However I don't have any of the documentation for these wheels.
I did find out a fellow member (TnRedeye) was the previous owner of my car.
Maybe you can PM him for the info?
‘16 A8 Shaker
I wanna run 16/33 w no poke
Can you recommend what offset I need?
Lol
Make it fit - frame it tub it : )
Or maybe don’t try to fit 335/345????????
Discussion Starter · #4 ·
Lol
That may end up happening... Taking some measurements and crunching some numbers using my old fitment assuming fender is exactly 1.75" wider, using an M&H 390/40r17 section width on a 17x11.5 +1 will run it right to the edge of the fender while the inner wall should end up where my old tire was against the fender. I might end up buying one wheel just to verify fitment. LOL
1 - 4 of 4 Posts
