1 - 13 of 13 Posts
M6 2016 Hellcat challenger just hit 50k. I was told to change the differential fluid and transmission fluid. I don’t want to mess this up and want to get the right stuff. So please guys help me out what fluid brand should I get for the differential and m6 transmission and how much quarts should I get for each. I searched but I really couldn’t make the right decision on what to buy. Appreciate it thank you.
Ok, who told you????????? Have you read the manual? My Charger said ONLY if it's a fleet vehicle.
i read the manual I understand it says it’s supposed to be life guaranteed but was at a car meet and apparently a lot of the guys changed there diff fluids at 50. I also don’t baby this car but again do I really need it then that’s why I’m coming here for everyone’s advice.
i had the M6 and diff fluid changed at the dealer in my white car. $100 each maybe? i don't really remember
Discussion Starter · #9 ·
I did call parts up at a local dealer. They said they are using mopar atf+4 for the manuals for 6 quarts a case is 91.00. Is that right or is there a better brand for the money? Also is the mopar atf +4 ok?
There were some long threads on the topic of diff fluids. Someone posted some actual test result data. The takeaway was:
It takes 1.16 qts
It must meet GL-5 spec
Recommends 75W85
The Mopar supplier is actually Castrol
It needs LSD additive, whether it comes with it or added separately.
Top brands were:
  • AMSOIL Severe Gear 75W-90
  • Red Line Synthetic 75W-90 (or 75W-85 is fine)
  • Castrol SYNTEC 75W-90
brands/fluids to avoid (they all failed the tests one way or another):
  • Torco
  • Royal Purple Max-Gear 75W-90
  • Valvoline High Performance 80W-90
  • GM Synthetic Axle 75W-90
  • Mopar synthetic 75W-90 w/Mopar LS additive
  • Pennzoil Gearplus 80W-90
  • Mobil 1 Sythentic 75W-90
  • Pennzoil Sythentic 75W-90
  • Lucas 75/90 Synthetic
  • Castrol Hypoy C 80W-90
  • Valvoline SynPower 75W-90
For transmission fluid:
stock is Dexron III ATF (mopar ATF+4)
Tremec recommends Mobil 1 ATF full synthetic for the TR6060.
The full system is 4.2qts--you have to flush the aux cooler and cooler lines also.
Toddy (BBG) recommends frequent fluid changes on the M6:
  • transmission every 3k
  • diff every 4-5k
Under hard usage the diff needs more service. In the SRT manual it says to change the diff fluid after every 4 hours of track time to give you an idea.
Mopar ATF+4 is fine.
1 - 13 of 13 Posts
