Unable to locate socket. Problem started abruptly on trip to Los Angeles. On the road, not a result of work done. Probably original flasher in there. Thanks.Can you find the socket on the harness? Someone took the flasher out? My coronet is 180mi from me atm unfortunately
Yes.But if you do left signal do only lefts come on and stay on?
When you activate the hazzard flashers, do they all flash?Yes, the Bullhead connector has been a source of heartache over the years. It was recently gone through/sorted due to an intermittent engine shut off problem.
