1 - 18 of 18 Posts
Which is a good slick to use I have a factory 2017 20inch rim just want some good everyday slicks to put on. Any good tire men here?
Go Nitto 555R2 in the proper size . 275. Do NOT go bigger than 285- you will get less traction, less stability and less cornering - trust I was warned and decided to learn the hard way. Buy tires that fit your rim .
Reactions: CGSRT707
‘16 A8 Shaker
I suggested a 3402 thinking the hellcat came with a 10 or 10.5” wheel
3401 if yers came w 9’s out back
Stay away from nitto. Mickey works better : )
2021 Redeye Super Stock
There are R888Rs, NT555R2s NT05R’s, and a few others that are all decent drag radials for the street. But in your post, you said “slicks”. If you want a drag slick for track only, Sticky Mickey’s (Mickey Thompson’s) are probably the best if you can find them. They seem to be out of stock everywhere like a lot of other tires right now however. Though opinions vary greatly around here among users of each! Really depends on your intended application of street or track.
So the standard size 305 tire is worse?
A 2017 car is going to be a standard body, not a widebody. 275 is stock size.
How about some Continental Extreme Contact Sports. Hopefully everyone catches that as sarcasm.
‘16 A8 Shaker
The rim is only 9.5 wide so 3401 (“275”) will sit flatter at the same pressure than a 305 would
Ya don’t wanna squeeze the tire on the rim, Mickey’s work better the other way around. Work best w the dimension between the bead wider than the tread.Even the 3401 has more than 9,5 tread
And no one makes a ‘slick’ for a 20” wheel
if you have a 9.5” rim in these cars a 305 tire will perform worse than a 275 or 285 of the same tire- the car squirms under heavy throttle, tires don’t corner worth a shit and the contact surface of the tire is distorted and you don’t get anymore contact patch- I’d argue you’ll get less .
i was warned by people before I did but I “knew better”. Only to learn the same lesson at my expense
Reactions: Chunky White
What does your RE 60 on that tire?
haven’t tracked this car yet - it has 1100 miles on it- and it’s in Canada I’m in Florida and haven’t been home for 6 months.
Probably a mid-high 1.6 is possible with that rubber and good conditions - just my estimate
1 - 18 of 18 Posts
