I started my rear suspension work today. I watched @Speedy and his two videos and another by Kelleys Garage. That had me pretty confident I could get it done.
To start I got the car up on jack stands. Removed my track wheels and tires. Put my stock NT05s back up front and started in the rear.
First I marked the cradle mount points at 90 degree angles so I can reasonably get the cradle sitting back where it was when I dropped it. Thanks again to @Speedy for that great tip in his video. Then I pulled all the clips around where you need to so you can get access and move the plastic around. Then I pulled the brake line bolts to get some slack. Finally I dropped the back and mid exhaust mounts just so I could have plenty of room. I think I probably could have gotten by with just the rears but it was not too bad to drop the mids either.
Man my wheel wells are dirty...
Next up I put the jack under the diff and loosened the left side shock up top and the 2 18mm cradle bolts. Then back over to the driver side I took out the upper shock bolts then pulled out the cradle bolts on the drivers side. I lowered the jack small bits at a time making sure nothing bad was happening and kept checking the upper arm bolts for clearance. You have to about max it out on the fuel filler to get good clearance for the front upper bolt.
Next I drilled the front tab off. (See speedys video)
Had to do 2 holes because the first one i started too low and the big bit dropped out.
Next popped in the upper cradle lockouts. The small one up front with the rounded side down and the bigger one in the back. Used a big set of channel locks to seat them well.
Decided to do the center upper control arm first. It is specific left and right so make sure you pick the right one.
Then I did the upper forward arm.
Tops all greased/torqued/done. You do need an assortment of extensions and a swivel to get the right angle to remove and install.
Next the lower control arm.
