Both should be same part number.
You will need actuator 68230108-AG
And spring 68319331-AA
Hopefully this helps.
Thanks for the quick response!Both should be same part number.
this is correct, I will need to buy each actuator and the AES kit to get rid of the code.If the previous owner installed a full cat-back Flowmaster exhaust (as opposed to just splicing in some mufflers), it should have the valve eliminators already on there, so you shouldn't need anything but the actuators/springs. Check pic below to see if yours has something similar.
I say this, because my exhaust doesn't quite look like that, it is flowmaster, but I didn't see those brackets...this is correct, I will need to buy each actuator and the AES kit to get rid of the code.
I will get some pics underneath this weekend, when get some time.
Sent from my SM-G955U using Tapatalk
That's what I'm guessing at this point...Do you think then your car may not have been tuned?
~Linda
I looked up the part numbers and they differ left and right, but you got me headed in the right direction, thank you!Hey tac,
Might want to check with a dealer on part numbers just to confirm. Out of curiosity I watched the aes video. In it he stated the actuators have different part numbers. The one I gave you was passenger side. Sorry for the confusion if I caused any.
I only know that number because mine was replaced ( pass side only).
I'm thinking he cut it out, unless im looking in the wrong spot, I posted some pics, let me know what you thinkFlowmaster only has 2 choices for the Challenger HC, basically differing in the mufflers (big cans like in the pic above, or skinny ones), but either should have the brackets that the actuators bolt to and function as a simulator. It allows the actuators to go through their motions/test to avoid throwing a code. Did someone modify the stock system and cut out the stock mufflers and valves and just install some mufflers?
Hope you get it worked out either way!
Well it looks like a complete Flowmaster cat-back (has the proper H-pipe) "Outlaw" system (AKA "damn loud"). I double-checked (see the Flowmaster site) and while there are 2 "American Thunder" options and 2 "Outlaw" options, the pics are basically identical (perhaps in error??), however it seems that only one of each type indicates an "active exhaust" provision. If that is the case, and I'm not sure why they would even offer one without the active exhaust solution, then perhaps you have one without it? I can't quite see in your pics if the bracket for the actuator is there or not. They would be past the rear mufflers, just beyond the exhaust hanger, on the outside of each pipe, like in my picture posted previously.I'm thinking he cut it out, unless im looking in the wrong spot, I posted some pics, let me know what you think
I stand corrected, I wasn't looking far enough back...Well it looks like a complete Flowmaster cat-back (has the proper H-pipe) "Outlaw" system (AKA "damn loud"). I double-checked (see the Flowmaster site) and while there are 2 "American Thunder" options and 2 "Outlaw" options, the pics are basically identical (perhaps in error??), however it seems that only one of each type indicates an "active exhaust" provision. If that is the case, and I'm not sure why they would even offer one without the active exhaust solution, then perhaps you have one without it? I can't quite see in your pics if the bracket for the actuator is there or not. They would be past the rear mufflers, just beyond the exhaust hanger, on the outside of each pipe, like in my picture posted previously.
Did they cut the actuators out or just unplug them? Are they tied up somewhere to the underbody (sorry if I am stating the obvious here)?
Otherwise, like you've said, you will need the left/right actuators and AES kit, or alternatively, look into a different cat-back or try and find a local stock take-off exhaust assembly. Sucks either way.![]()
Thanks for the help!Well it looks like a complete Flowmaster cat-back (has the proper H-pipe) "Outlaw" system (AKA "damn loud"). I double-checked (see the Flowmaster site) and while there are 2 "American Thunder" options and 2 "Outlaw" options, the pics are basically identical (perhaps in error??), however it seems that only one of each type indicates an "active exhaust" provision. If that is the case, and I'm not sure why they would even offer one without the active exhaust solution, then perhaps you have one without it? I can't quite see in your pics if the bracket for the actuator is there or not. They would be past the rear mufflers, just beyond the exhaust hanger, on the outside of each pipe, like in my picture posted previously.
Oh and yes, these are extremely loud! Every tunnel I hit here in Portland is a deafening roar when I go through!Thanks for the help!
Sent from my SM-G935T using Tapatalk
