So a few weeks ago I had a torn axle boot and got grease all over the actuator. Cleaned it thoroughly put everything back on. After that I noticed the valve making an opening and closing noise about every 30 seconds to 2 minutes even when the car is locked and keys not in range. After a day or 2 this stopped and noticed I have a code for both valves. Is it possible that the one actuator I cleaned got water or break clean in and fried it? Then this caused the ecm to shut the whole system down? Should I replace the valve that got grease on? How do I reset the ecm to make it read them again? Both codes are permanent and pending
