1 - 11 of 11 Posts
Simply curious, when adding front skinnies and removing passenger/rear seats, how many tenths do those two modifications alone shave off at the track in general?
Do you feel a noticeable difference at the track when adding skinnies and removing passenger/rear seats or not really?
if you are really racing for times and want to win, everything helps...if you are just having fun at the track, don't bother
· Administrator
The skinnies will get you a just under a tenth gain. As far as removing seats I only have done the rear for a 40+/- lbs saving.
So the 2 together maybe a little over a tenth.
Now this is my experience with my car and you will get many say otherwise.
I have run with stock and skinnies on the same day quite a few times. And on average say 3 passes to 3 passes the gains are a bit less than a tenth every time.
The passenger seat I don't remove as that disables air bags.
The rear seat removed at the track was about .02 on average the three times I did that.
Still any gain is a bonus, a 10.5x sounds better than a 10.6x .😉
Discussion Starter · #7 ·
Nice, thanks for sharing, as you mentioned others experiences may vary. So it seems like in your experience the skinnies at best maybe a tenth alone if not just slightly under.
When you removed the rear seats it was 2 tenths alone or in combination of the skinnies as well?
Correct me if I'm wrong but when you added skinnies plus the removal of rear seats was at best a total of 3 tenths shaved off if not atleast 2 tenths?
· Administrator
No not 2 tenths for the 40lbs. More like an average of 2 hundredths. So a tenth or a little better for both.
A bunch of small things do add up though.
‘16 A8 Shaker
You can’t just say ‘skinnys’…
Lite wheels ($1000+) are worth more than my heavy ass Chinese wheels ($100)
3880 mt et R front was made for our heavy cars but is no longer available. Which tire are you talking about? I have heard people say their car slowed down running the m&h tire I run. Slowed down swapping out 20” 275 for them. Which tire n which wheel?
The seats are what they are. Take em out n weigh em and search for formula and see how little it’s worth. It’s math
I think they say about a tenth for every 100lbs? though I dont think thats 100% accurate.
I spreadsheet all my runs and have my PB's at full weight with the stock 275's up front and in very similar DA (though I always run a lithium battery which only weighs 5lbs) vs pulling the seats, trunk weight etc. I have never run smaller tires up front though will probably give them a try at some point.
1 - 11 of 11 Posts
