When you let off having a spike in afr is normal.
Thanks.Normal
Your temps are normal too in stop and go traffic. I had to do the conversion but 212F coolant temp at stops is normal with the OEM thermostat. As far as the CEL, mine overheated at 250 miles due to a stuck thermostat. If I recall right the warning light came on at 240 or 250F. I could be wrong though. I made a thread about it maybe I mentioned it in there.Thanks.
Any idea about the IATs?
SG
Could you post the link to the thread.Your temps are normal too in stop and go traffic. I had to do the conversion but 212F coolant temp at stops is normal with the OEM thermostat. As far as the CEL, mine overheated at 250 miles due to a stuck thermostat. If I recall right the warning light came on at 240 or 250F. I could be wrong though. I made a thread about it maybe I mentioned it in there.
Good to know.Intake on a hellcat won’t affect any major changes on a hellcat. 15-16 had a maf but it’s not used for fueling.
Hi, it was 250 when the light came on http://www.hellcat.org/threads/2016-challenger-hc-overheated-250-miles.15731/#post-363234Could you post the link to the thread.
Good to know.
SG
I put my OEM intake back on to see the IATs and it is similar to AFe or even hotter. Still seeing 80C IAT with 41C atmospheric temp. SC coolant is at 60C.With all cold air intakes that are on the market are sucking hot air under the hood .
What many are thinking that the opening above where filter is positioned is grabbing cold air ..... They are very wrong.
The way this opening on the hood are designed is to draw air out under the hood.
So you are actually loosing power and your engine is sucking hot air.
You are lowering your air density .
If the noise is something you are after go for.... Otherwise Stay with the Stock CAI it is made good straight from factory.
If someone come with enclosed CAI that will have front grille integration to draw fresh air in the front of the grille and build postive pressure when speed increase that will be well worth spend money to have better than stock.
