1 - 7 of 7 Posts
21 Charger Redeye
I've been searching this for a bit and I haven't really found anything solid, or current... on the Charger, how much support do the 2 factory cross tunnel braces provide, and how detrimental is it to have them installed?
I installed a Carven catback exhaust and neither brace will fit after install. I can get a bit of clearance between the Xpipe and the front brace, but it still hits when driving. Simple solution will be to add some spacers and call it a day; that said, the rear brace is an entirely different story. The xpipe to mid pipe connection/clamps are in the exact same place as the cross brace, and there is no way to install the brace.
I watched the Carven install video and it appears that they leave the braces off after install. I know that there are after-market braces available.
So the question remains; will I see tangible negative effects from the braces not being installed?
‘16 A8 Shaker
I wouldn’t worry about it. 4 door car. Has extra door jams to support unibody construction ha
How much tire ya got under that beast?
What’s it 60 foot?
2018 Trackhawk "not stock"
Reactions: Taxinator
21 Charger Redeye
Discussion Starter · #5 · (Edited)
What’s it 60 foot?
For now it's on stock size Conti's. I've got a set of 17" Forgestar's for it, but unfortunately MT's in 315/50 are backordered for eternity...
I put these under my 300.
I was looking at those last night; they're priced pretty well and I may pick up a rear one.
can you space the factory brace down with some washers/longer bolts?
They are attached to the car with 13mm threaded studs and nuts. There appears to be enough thread on the front ones to install spacers, which I plan on trying. There is no way in hell the rear one will fit though.. I don't have any pics at the moment, but between the bigger piping and the fact that the joint for the Xpipe to Mid pipes is in the exact same spot; the stock attachment hardware isn't long enough..
The car is a weekend cruiser and will probably only see the track a handful of times, so it's not a huge deal, but I figure Dodge braced that area for a reason; I might as well try and keep it braced.. :LOL:
You will not notice a difference and it will not hurt anything. Those braces underneath are not in any way structural.
That said.
What a crappy exhaust design. How lazy do they have to be not to incorporate those into the layout like EVERY other exhaust company.
I would have boxed them and shipped them back on general principal.
F**k that.
1 - 7 of 7 Posts
