1 - 14 of 14 Posts
From what I can determine the 2020 OEM Dodge Challenger Air Filter is:
P/N 68424622AA used for: Hellcat, Red Eye, Super Stock & 2018 Demon (non crate).
The 2018 Demon "crate" air filter aka "Air Grabber" is P/N 82215544.
Questions:
1. Have I got this about right ?
2. Are both filters oiled ?
3. Are both filters interchangeable ?
Thank you !
DRIVESRT.COM
564193
@Octanewide
82215544 - Demon Air Grabber Performance Air Filter (Left) - has less layers than the demon stock filter.
05038820AC - Demon Stock Filter (Right)
Discussion Starter #3
Thank you Ray ---- accordingly I was wrong assuming the Demon's stock (non crate) filter was the same one used on the Hellcat and Red Eye which is 68424622AA. I'm now curious if the Air Grabber Demon filter 82215544 will fit the Hellcat and Red Eye ?
DRIVESRT.COM
It will. The bottom air box and the intake tubes that the filters connect to are the same.
Discussion Starter #5
Perfect ---- thank you very much !!!
That picture looks very familiar..
Here are a couple more including the 2019+ Hellcat
Discussion Starter #7
I'm guessing the Hellcat/Red Eye filter 68424622AA and the Demon stock/street air filter 05038820 may be identical except the embossed Dodge slash marks on the 68424622AA vs the Hellcat head on the 05038820 ?
DRIVESRT.COM
That’s correct
Not sure if this applies to the Demon Crate filter but a lot of the companies that make race filters do not record driving them everyday. They have very limited air filtering and allow bigger things into the engine.
Discussion Starter #10
Thank you Sunny --- I think we can safely put the Demon Crate Filter in that category !
DRIVESRT.COM
@Octanewide Can you post the filter dimensions? It would be interesting to know the surface area of the filter.
They are all the same size, difference is in the thickness of the filter media with the Demon crate being the thinnest and having that concave end cap which I guess helps flow. Barely or hardly noticable though with layers of filtration.
DRIVESRT.COM
It's a 7" tall filter?
Discussion Starter #14
I see what everyone is saying: ---- there's NO way to get the Demon Air Grabber filter 82215544 unless you own a Demon whereas It's strictly VIN locked !
Is there any alternative filters available on the market that flow better than the stock 68424622AA cone style filter for 2019 and up Hellcats and RED Eyes?
Thank you !!
1 - 14 of 14 Posts
