Is there an option to just turn it on in Hp Tuners or would i have to adjust the pump settings?No it is not. You can adjust pump setting with hptuners
Trying to bleed the system best i can after the spacers were installed.Bring a cooler with a bag of ice and bag the supercharger/coolant reservoir
Coolant hoses were disconnected when i removed the supercharger.Why would you want to bleed the system?
Gesendet von iPhone mit Tapatalk
Do you happen to know the promp for it? I looked through it last night and couldnt find anything. Would a brake bleed vacuum work on it?Have to vaccum fill it, but Alfa can run the intercooler pump.
No. Pretty sure you need something like thisDo you happen to know the promp for it? I looked through it last night and couldnt find anything. Would a brake bleed vacuum work on it?
It’s in one of the diagnostic procedures, just look. And now, @HC5120 csnctell you what to get to vaccum fill it.Do you happen to know the promp for it? I looked through it last night and couldnt find anything. Would a brake bleed vacuum work on it?
