Yeah, need to see the alignment printout.So I think I've exhausted all my options for the pull/tire shake.
I started off by getting an alignment, still pulled right. Then I went over and got the tires balanced. Still pulled right. Went back got the alignment rechecked, said it was in specs but had them flip the tires left right. Still pulls right.
Picked up new front tires since the pirellis are worn. Tires shake and it pulls right. I was told they don't use that "smart balance mode".
I'm making them rebalance them but if that doesn't work it's gotta be something else, I'll post my alignment sheet so you guys can look at it but, it might be something else at this point.
Smart Weight/Smart Balance Mode MUST be turned off after a fresh calibration. Take a minute and ask to talk to the wheel tech doing the balance. Chat with him, tell him the story, what you need and ask the tech to work with you.
Might have a bad R/F Wheel Bearing.
