Lord knows how many times this has been discussed, so I'll be brief as I was hoping for clarification
I've got an '18 HC and I'm going to pin the crank. There was talk about upgrading the bolt to the one used on the Demon however I read that at a certain model year they started using the Demon bolt on all HCs?
I'm using the Bwoody kit which comes with (I assume) the stock HC bolt however I also purchased the Demon bolt. Does it matter which I use?
Thanks in advance[/QUOTE]
https://www.hellcat.org/threads/demon-crank-bolt-and-torque-spec.205425/
