i'm zero help but that does seem very strange. i have a different brand cat back with valves and have never had a check engine light from the exhaust has been a few months and few thousand miles.
Thanks, it's frustrating as hell.i'm zero help but that does seem very strange. i have a different brand cat back with valves and have never had a check engine light from the exhaust has been a few months and few thousand miles.
I'm hoping that Linda can get a tech on here to help me out.i'm still zero help but I did have a borla atak installed last year only a week though and I didn't drive it much it was wayyy too loud for me. but in that week fri-fri maybe 100miles? I never got a check engine light either.
is the code for the valves?
when my car was new i fought a P0472 code for months it turned out there was a quarter size hole in one of my cats, some sort of manufacturing defect that would trip the light every 500 miles or so. a new cat and it's been good to go since.
I just spoke with Steve again, mine were the 1st ones with the new valves to be sent out. He's very frustrated to say the least. I've got an appt. with the local dealer on Thursday to have them look at & clear the hard MIL code. If that doesn't work Steve said to let him know, they will look up the build date & everything and send out a new set of mid pipes, as well as pay for the installation.I can't remember - does your Borla exhaust have actual valves in it or simulators?
In case you weren't aware, "The valve actuators are calibrated at every Key-ON event. The PCM sends full open and full closed commands and checks actual against commanded position. If for any reason the calibration is unsuccessful , the actuators are self-diagnosing and report fault flags to the PCM."
So as soon as you start the car, the valves cycle. They also will cycle with the car off if you unplug and plug them back in (you will hear an electronic tone when you do). I believe after a minute or so (or sooner), if they haven't cycled properly upon start-up, you will get a CEL (check engine light). But since you said you drove it for a bit, and didn't get a CEL right away, it makes me wonder if maybe the valves are cycling properly, but perhaps getting hung up once things get hot in the pipes. I dunno.
You shouldn't have to clear codes after each drive, as that just indicates the problem is still there. I have installed aftermarket exhausts on almost all of my vehicles, (including the HC), and have never heard of a car throwing a CEL because it hasn't "learned" the exhaust.
I'll have to look into that, any one you recommend?Hope it works out. I am sure it is frustrating.
BTW, you should buy a code reader. They aren't expensive at all, and will let you pull the codes, so even if you don't do the repair yourself, you can be informed when you take it to the service dept. Plus, you can clear the codes too.
I have this one and like it.I'll have to look into that, any one you recommend?
Ordered...Thank you!I have this one and like it.
Amazon.com: Autel AL519 AutoLink Enhanced OBD ll Scan Tool with Mode 6: Automotive
Did the problem resolve itself or did it come back?Okay, so here's the latest:
I'll have some more time tomorrow to drive it and see, I'll keep everyone posted.
The level 3 tech at the dealer reset the spring, reconnected the actuators, put it in run for several minutes and cleared the code.Did the problem resolve itself or did it come back?
What brand other than Borla comes with valves?i'm zero help but that does seem very strange. i have a different brand cat back with valves and have never had a check engine light from the exhaust has been a few months and few thousand miles.
You are correct...thanks!I think he meant to type "actuator" as opposed to resonator.
I meant actuators, and I too am hoping it's number 2, they'll be here soon.Thanks
1. Are you talking about the "cans" at the rear of the car? If so, why is the "dealer" looking for them? I assume by dealer you mean the Dodge dealership. Why would a resonator throw a code?
2. I think it is #2
