Not horn volume, actual horn not working. Here is what I checked:
power to fuse panel
power to coil
power to common point on relay
independent test of relay
+12 V to NO contact of fuse block makes horn work
It's as if the relay is not getting a signal to close the coil in the relay. Started noticing that the horn beep was sporadic when locking the door. Now honking the horn does nothing. Setting off the panic alarm only flashes the lights.
Any ideas? Anyone else experience this?
power to fuse panel
power to coil
