I have a 2022 Challenger SP WB on order. I wanted to go ahead and get lowering springs to install when it arrives (in production now). Anyone have experience with BMR Lowering springs? Pictures? Thanks.
Thanks for the reply. I was worried they may be really low. Ordering the Eibach.They sit low as hell.....go with the Eibach Springs!
My 2013 challenger that was lowered experienced a leaking boot. At the time I never read any problems with lowering and didn't think much about it. Not really worried about it.Also read up on what happens to the widebodies when you lower them in regards to axle boot damage... and make sure this is something you can live with. It's a very well documented thing around here.
Now, compare the cost of the axle on a Hellcat and the axle on your 2013My 2013 challenger that was lowered experienced a leaking boot. At the time I never read any problems with lowering and didn't think much about it. Not really worried about it.
Please elaborate. I was considering the eibachs.Also read up on what happens to the widebodies when you lower them in regards to axle boot damage... and make sure this is something you can live with. It's a very well documented thing around here.
There's some good info in this thread:Please elaborate. I was considering the eibachs.
Hmm not a lot of info there. I’ll keep my search going. Just seems like it may or may not split no matter the height.There's some good info in this thread:
Leaking axle boots if lowering??? Wtf
Ive been reading up and seems a lot of people keep busting axle boots if lowered..... some stock height alao but seems to be more apparant on lowered challengers. Anyone have a fix? I really want to lower my care more but just dont want to deal with the hasslewww.hellcat.org
The above is a general comment on what the rear does at lowering. With a widebody car, the angles are the same, but the length of the halfshaft puts compounded stress on the boots, which accelerates failure.This is why you see a lot of air ride systems fail as well. With air ride, the lines can get pinched or cut if they're not routed well away from obstructions, but due to how low they bring the car and increase the negative camber, it greatly wears on the axle boots. Eventually causing a failure. So long as the car isn't driven when lowered near the max of its depression, it's not too bad. But there are people who like to drive it slammed... and those people might get weeks or months out of their axle boots on a widebody.Lowering increases the working angles of the CV joints which in-turn causes the bellows on the boots to rub against themselves due to misalignment.
I can go to the garage and grab a half shaft to demonstrate this if it is beyond anyone's grasp.
A lowered car, under compression, has serious camber gains which further exacerbates the issue.
So either you realign it with custom arms, or change the layout/construction of the half shafts to something without a cheap boot.
