Anyone using K&N HP-2010 oil filter
305 Views 5 Replies 4 Participants Last post by  David Neibert
I'm using this type filter on my other car because it's much easier to remove with a socket wrench. Thinking about ordering some for my Hellcat but would like to know if anybody here is using it first.
1 - 6 of 6 Posts
Yes, top rated filter plus has that nut for easy removal.
Sent from my SM-G781V using Tapatalk
I use the MOPAR filter. There is plenty of clearance to use a band filter wrench….. just FYI you don’t NEED that type of filter.
You Sir also don't "need" a Hellcat. The K&N filter is superior to the Mopar brand either the white one or that black one. Have you ever looked inside a Mopar filter at the small metal louvers that oil flows through? I have and had some of the so called better with SRT filters have crushed or severely bent closed.
You can run the Mopar filter and use one of these, 93 mm 15 flutes.
Yeah, I just did that last week and it wasn't a big deal to get the strap wrench on the filter. I just prefer to use a socket & wrench.
1 - 6 of 6 Posts
