1 - 20 of 40 Posts
The person selling is claiming they’re the newer style 4 piston calipers on the front as well as rotors. Well, all the pictures I’ve seen with the new style front calipers (I believe 2021+) they have no slots at all in the rotors. These have slots so I’m just confused as to what everything really is. I’m trying to run 18s but the 6 pistons won’t allow, I want the new style brakes so if these are them then cool
Yep, 4 piston. You can see the 2 pistons on each side of the interior without the pads. Also, the casting on the exterior part of the caliper shows the outline of the 2 on each side.
I have seen an R/T at my work that has brakes that look like these though. I’ve searched a little, never figured out where the fronts come from.
I don’t think it was a factory option but I don’t know much about the R/T.
‘16 A8 Shaker
There are at least 2 different versions of 4 piston fronts. My shaker has a different bracket than the SS (or whatever it was) don’t remember which trim but different brackets for sure. Might need the brackets too : )
Discussion Starter · #18 ·
Damn, I have no idea what you’re talking about. Are these brackets able to be ordered from dodge ?
@SickToo doesn’t know what he’s talking about half the time either. Those calipers are pretty beat up. What kind of 18” wheels are you trying to fit on the front? Certain 10” skinny drag wheels will fit on the front with the 6 pot brembos
Discussion Starter · #20 ·
I have some super stock rims I wanna put on with some Mickey Thomasons. So 18” but as we know only the 4s will work. I like the newer look more so hopefully these will work without any extra bs. But they are beat up so idk and they’re expensive I may just find someone to do a swap
1 - 20 of 40 Posts
