1 - 6 of 6 Posts
since yesterday i have had strange noises from the engine or from the supercharger
it sounds like a squeal from the brakes
it is only when it is warm and it squeaks every 5 seconds
i sprayed the belts with silicone but the noise came after the first throttle was idle again
car has been 11k miles ...
Another car manifested a faint chirp at idle. Turned out to be a bad idler roller bearing.
If you want to before you take the car in you can try to ID the source of the noise. I had a mechanic's stethoscope in my toolbox that was handy for this. Be very careful around the running engine and its accessory drive/supercharger drive systems.
2016 Bright White Challenger
tensioner pulley died on mine and sounded the same. Put a long screwdriver to it, and then your ear to hear the vibration.
Discussion Starter · #4 ·
do you think it's the blower pulley or a other?
another question ... can i start the engine wirhout the supercharger belt
Thank you for answer
I think its the tensioner one, since you don't have constant issues, a S/C bearing being bad would always make a noise, the off/on issue leads me to believe its not the blower. and you cannot unfortunately as its your means of intake air.
I would take the belt off and spin the tensioner and idler with your hand, and see if you can feel friction
1 - 6 of 6 Posts
