Has anyone found battery acid in the battery tray? My 2020 HCRE would not go into race cooldown mode because of the battery status. Turned out the battery had low CCAs and after the battery was replaced problem was solved. Shortly after the dealer replaced the battery I got to looking and found corrosion on the battery hold down bracket and in the tray. Removed the battery and found liquid, highly reactive to baking soda...battery acid! What a mess...vent tube was connected but the spare vent port on the dealer newly installed battery did not have a plug installed. Questioning of the dealership revealed that the battery acid was present at the time of the battery replacement and an unawareness of plugging the unused vent (no comments necessary). I suspect that the factory battery did not have the spare vent port plugged but can't say positively. So I looked into my HPTuners date logs and had recorded PID "Control Module Voltage" (thanks Brian of You Tube's B Mason). I used >14.5v as the Min Limits criteria in the Charts and found numerous instances when that voltage was exceeded. In every case it occurred during and immediately after a WOT pull to around 100mph and lasted 14 to 20 seconds comparatively long after WOT no longer existed. (RPMs in the 5200 to 5600 did not meet the criteria.) The max value was always <15v. From reading other battery/alternator posts in this forum and because the duration that my voltage was above my criteria was in my opinion short, I am moving away from a charging issue being the cause and suspecting a missing vent plug. I am not fully up to speed on the Dodge charging system or lead acid batteries so any insight would be appreciated. Thanks
